t1mpani
Platinum Member
- Jun 6, 2002
Just wanted to throw an idea out here; I'm working on re-handling a knife for a friend of mine. It's a hidden tang and the transition from ricasso to tang has no curve to it at all, just a 90 degree shoulder. I'm wondering if I couldn't actually strengthen it by using a round file to cut arches into the two shoulders--even though removing material, it should help distribute forces into a larger area than it is currently. The tang is 3/4" wide, and the way I'm thinking it would neck down right at the front to like 5/8" or so. I have a few pretty skinny round files and would only grind until the existing angle was removed. Kind of like using a hole saw at the juncture points on a set of stair stringers.
Make any sense?
I'm sorry if this has already been covered but I tried "remove stress risers" and a few other combinations and while I found a good bit, it all seemed to be how to make a knife correctly from the start. I'm trying to make one correctly after the fact.
Make any sense?
