Hi,
Just learning on my Norton India Combination stone. It seems like alternating, light strokes at the same angle of sharpening don't remove the burr. When I increase the angle a little, this seems to remove the burr better, but am I creating a micro-bevel by doing this? Is there a smarter way to remove the burr?
Thanks,
Jason
Hi,
Cutting off burrs with high angle edge leading passes is about as good as it gets (its like magic
And yes, you are creating a microbevel,
and if you slice some paper newspaper you can even hear the high angle make noisy slices,
but its not a problem , at least not for long,
if you did 1-2 alternating edge leading passes to deburr
then 1-10 alternating edge leading passes to backsharpen
it will get rid of the microbevel to where you can't hear it or feel it anymore
Try it out, sharpen, raise a tiny burr, use high angle passes to deburr,
then cut some printer paper or newspaper, slice push cut whatever,
listen to how it sounds very noisy,
then do 1 alternating pass per side at original angle,
and cut some paper and listen to how it sounds
in under 10 passes per side it will stop sounding so very noisy and get much much quieter
High angle deburring, its very powerful
[video=youtube;oRmcQ-MqbBE]https://www.youtube.com/watch?v=oRmcQ-MqbBE[/video]
[video=youtube;EcrnigC3Anc]https://www.youtube.com/watch?v=EcrnigC3Anc[/video]
[video=youtube;_STUM1z8iJM]https://www.youtube.com/watch?v=_STUM1z8iJM[/video]
