- Apr 6, 2009
i'm looking at my kershaw chive and scallion and since the thumb studs are so hard- for me- to use i'm thinking about taking them off. anyone else done this or see any reason not to?
how are you going to open it?????????
Taking them off will leave you with a near useless knife.
These thumbstuds are not screws like most, but bolts. You can tap them through with a small hammer.
Screws and bolts both have threads so I don't think you meant bolt. Not sure what the correct term would be if it is press fit.
Well now I just picked up a BM 950 Rift, and was wondering the same thing. As someone else mentioned in a previous post, the Rift is a little hard to open due to the thickness of the handle. So I want to replace the stock studs with something a little taller/ bigger. Anyone have any knowledge about the studs on Benchmades?
The thumbstuds on Benchmades are just screws.
Do you think they're all the same size? Should I shift thru the BM catalog and find the thickest blade, then order a replacement set of those? Would they be loose on the Rift's thinner blade?
I dont mean to sound like an idiot, but, I guess I am.
