Removing 'Zaan thumb lugs?
bruleront
Anyone have any tips on safely removing the thumb lugs on the Umnumzaan? Probably going to satin finish the blade if I can remove the lugs without damaging them.
Thanks.
Careful....they are a pressed fit and not meant to be removed.....CRK also did a revision on the early models.
I think you could satin finish the grind and leave the flats stonewashed.
This would allow for the studs to remain on during the process.
I personally think this would look much better.
I just might do this myself also:)
dave
At this time CRK will do no modification on Umnunzaan's, I already called to have my blade & handles polished & Heather said they are not doing anything on that knife at this time.
:D:D:D Rickster :D:D:D
If you're going to make the effort why not go mirror polish for the entire blade? That'd look way sexy, and make a nicer contrast to the handle than just going satin on the blade. You'll need new studs I reckon as you won't be able to un-f*ck the ones you take out of your knife afterwards. You could send it in for new ones though.
