Science! Thank you! I was afraid of using mineral spirits because I didn't want to take the chance of discoloring the G10. This oil method worked great. It was a little slow but slow and clean is better than fast and dirty!Renaissance Wax is mostly microcrystalline paraffin. It's able to be cleaned with non-polar solvents. Isopropyl alcohol will not do a very good job, as it's a polar solvent. The least-harsh method of removing it will be a little bit of oil allowed to sit on the surface for a bit, then scrubbed with a brush and cleaned with soap and water. If you have mineral spirits or naphtha it will also remove it, but is more likely to have an impact on the G10 due to being much more powerful solvents. That being said, those are probably safe on it. G10 is pretty chemical resistant.
Floor waxes are commonly complex emulsions containing not only wax, but products like shellac and soaps. It's likely the ammonia is being used to attack those elements of the floor coating rather than the wax itself. If you were to take a piece of solid carnauba wax and put it in a bottle of ammonia it would not dissolve. It appears, for instance, as though ammonium palmitate is often used as an emulsifier in floor wax emulsions because of the fact that ammonia water will dissolve it, but it will form a hard, clear, and water-resistant coating when dry. So ammonia itself is ineffective on waxes, but may be used to advantage in some emulsions. As the wax in question was a nearly pure paraffinic wax, ammonium would do virtually nothing to it.Strange-ammonia has been used to strip floor wax for decades.
I guess it just doesn't work.
Gentle heat from a heat gun or hair dryer is usually sufficient for those purposes. However, as a chemical remover, some googling seems to indicate that Loctite is based on poly-methyl-methacrylate (PMMA -- the same polymer as plexiglass, also known as acrylic), which dissolves in ethyl acetate--a common solvent used in many nail polish removers due to its low toxicity and fruity aroma. I also see ethyl lactate being recommended by some sources as being especially low toxicity to humans and the environment. Acetone also works, and is actually used in the production of plexiglass as a precursor chemical. Loctite themselves makes a stripping compound they call "Chisel" that's mostly methylene chloride and would also work. All told, though, a high-strength nail polish remover of one kind or another will probably do the trick without damaging G10, and will be the easiest to source economically.Science! Thank you! I was afraid of using mineral spirits because I didn't want to take the chance of discoloring the G10. This oil method worked great. It was a little slow but slow and clean is better than fast and dirty!
You wouldn't happen to know what dissolves loctite that is safe on things like G10/carbon fiber/micarta, would you?
