Na are the handle slabs secure and tight? If so then it's usable or should be. How is the bolster loose and is the butt cap loose as well?
Shrunken horn is the biggest problem with Chiruwa handles and one of the reasons I don't care for them. Depending on how wide the gap is between the slabs and the handle depends on how you can fix it. If it's not very wide at all you may be able to get away with using some of the superglue in gel form.
If it's wider then you will want to get some epoxy in the cracks.
I don't know how old you are or how much experience you've had with cars but there are a couple of ways to get epoxy into the cracks.
One is to use the Devron 2 ton 30 minute setup glue and mix some charcoal dust in it after you have it mixed up and then drizzle the glue into the cracks using a toothpick or similar.
Two is to use the solid epoxy that you have to mix together like kid's clay until it's a solid color with no streaks and then putting some on your palm press it in like you would wheel bearing grease into a clean wheel bearing.
You can also buy yourself a *good* flat bastard file either 8" or 10" long and be sure to get a file handle for whichever one you buy.
After putting the file handle on the file you can then file the tang that's sticking out beyond the horn down until it's flat and no longer sharp.
Actually if it were me I would do that first and then epoxy the gaps between the slabs and the tang.
Some of the other folks here may have easier and better suggestions than I do.
I strongly dislike Chiruwa tangs.
