Our leaf spring material is made from the steel recommended by the world's top custom automatic knife makers and is composed from carbon stainless steel, heat treated to the government specifications for springs, at 40-45 rc. Our springs are not 301 or 302 work hardened stainless steel. You can have comfort in knowing that our spring stock will not get weaker over time like work hardened spring stock will!
What's the ideal thickness? The broken piece measures 0.073" at the tip thickening to 0.081" at the break, which is 0.1" from meeting with the back spring.That's not thick enough for your knife. It won't work.
Thanks. I've done similar fittings in non-knife tinkering without heat treating. As I waited for a response, I was thinking that 1/8" square rod would be ideal. Thanks for cluing me in on the alloy and heat treatment. Is it okay to use filtered used peanut fry oil for quenching?When I make springs for Italian autos, I start with 1/8" 1095 (usually.) I cut the spring to approximate length, eyeball the thickness and taper. Bend properly to shape. Clean. Heat treat to cherry red throughout the spring, quench in room temperature canola oil. I then clean the spring to bright steel and temper with a small, soft torch flame to just past blue and let it air cool.
You will have to grind the inside of your backspring down considerably, and either slot it or dovetail it at the rear of the knife. If you use a slot, it should also have a slight dovetail to prevent the spring from coming out.
While you may do it successfully, this repair usually requires some experience.
I saw mine out of sheet, but square steel is ok.
I was under the impression that it could be done with 1/8" square rod. Maybe I could make it work if I went with the approach of sticking the root of the spring into a notch, but now prefer the dovetail approach. Thanks.As I said, I cut my springs out of sheet.
