Just in case anyone else has run into the following problem: I recently bought a Spyderco folder in the Marketplace and tried to remove the aftermarket scales to replace with the original ones. I tried to use a Titan wrench set to remove the screws, but a couple wouldn't budge. Looking at the T6,7,8,9,10,15 side, they were not lined up evenly, which didn't bother me too much; however, the T6 was about 1/5" longer than any of the others. Taking a magnifier to the ends, all were flat except for the T6, which had a rounded edge. I filed the end down until it was flat, and it worked fine.
Probably an obvious solution, but thought I'd share since it baffled me for a while.
