Repairing damage on wood scales
I finished a knife today and was so careful not to damage the wood scales. I peened 3 rivets without a problem but was so upset to see that I had damaged both sides near the back from the vice. I was ready to re-do the scales but thought I would try to rehabilitate the wood by soaking it in water. Wow. After about 5 hours soaking it came out as good as new. No sign of the damage that I caused with the vice. Made me feel that someone was on my side. Hope this tip can help someone else. Dave
Let it dry and touch up with fine sanding (you will probably have raised the grain after a 5 hour soak),you should be OK.One concern with that long a soak is how much water got into the tang area.Depends on the type of wood,glue, and steel used as to how much this may cause a problem.
Another good trick is to place a damp cloth over the ding and use a hot iron to "steam" out the dent.
Stacy
Stacy
I finish gunstocks quite often, and the damp cloth/hot iron technique has worked very well for me.
