wildmanh
Part time Leather Bender/Sheath maker
- Jul 9, 2000
I'm working on repairing JKM1's M43 that had a crazy thin edge and thought you all might like to follow the progress.
Got the blade from him a few weeks ago and tested it out on the wood pile in my back yard. The blade cut really deeply into 4x4 pine posts and logs. I spent 40 to 60 minutes between two days beating on the edge but could not replicate the problem. I even tested it again my 18" WWII model. JKM1's M43 bit deeper into the logs then my WWII. After making a ton of wood chips and splitting a few days worth of kindling I desided to chop and split nothing but knots and the bugger the knot the better. After busting through 6 to 8 hard thick knots I was finally able to get the edge to deform. But the spot that deformed for me was just above where JKM1 got it to. I'm guessing that the thin edge was work hardened in the waved areas.
This afternoon it was nice, I was feeling well and wanted a break from building sheaths to I pulled out the M43. This time to work over the edge. Spent about 45 minutes changing the edge on my 30x1 belt sander and a used 180 grit belt. When a belt doesn't cut leather the way I like it to I set it aside for steel and wood working. Today a belt was starting to get duller then I like so it was perfect for this. Hope you get an idea of the current edge.
I gave the M43 a thick secondary convex edge. The main grind was mostly flat and way to thin at the edge. Will do some testing in the next few days to see how the edge works, see if it's to thick or thin, how it holds up to hard use and all that good stuff. Will keep you all posted with future developements. Thanks for looking!
