- Dec 11, 2000
Can anyone give me an idea of how many times one can (try to) heat treat a blade of O-1 before wrecking it? I have been attempting to heat treat a small blade ( 2 x 0.5 x 1/8) using a propane torch. This is my test/practice blade. At present it is mostly hardened, all but the rear-most 1/8 of edge, the hardened area runs from the tip to a line starting halfway down the spine and going diagonally to just in front of the riccaso. I am not real pleased, but it took 4 tries to get it to this point and I am worried that to carry on will have some sort of adverse affect on the steel. As it is now its edge is hard, if I try to harden it again (having sharpened it once) will I ruin it. I have heard that carbon leaves the steel during heating, but am unclear about the temperature and effect.
Also, should a blade fail to get fully hardened, what is the correct procedure? Does it need to be annealed again before another hardening cycle is attempted? My problem with hardening seems to be getting the entire blade all the way to non-magnetic, I have read that this is also what is needed to anneal it.
Thanks
Chris
Thanks
Chris
