Replacement CRK pocket clip
Does anyone know where you can buy a replacement CRK pocket clip for Sebenzas/Umnumzaans? The one that came with my new Zaan is a little wonky. The small retention dip in the clip is raised due to the flat spot of the clip not being parallel to the handle. I've looked all over the web, but I can't find anyone who sells them.
Take the clip off and lightly hone the side that goes to the knife. You may have to do the edges ever so lightly also. Sometimes a burr is left from the factory and the flat part of the clip doesn't fit flush with the indention for the clip.
Thanks for the advice. I should have been more specific. The flat part I was referring to was the area between the screw and the dip. This area is not parallel to the handle, and thus the gap between the clip's "dip" and the handle is farther that it's supposed to be.
Is there any reason you just can't bend it to the shape you want it to be ? I'm not sure I'm really getting what the problem is here, pics would be very handy. :)
You can adjust the clip, tape the flat part and put it in a vise, bend the clip for adjustment and it should fit tight on the frame. The clips are cold formed and any adjustment will not effect the strength of the clip. Pics also help to really understand what's going on.
