- Oct 25, 2000
Alright, say what you will about it, but I did something pretty dumb tonight. I decided I wanted to try to remove the latch from my 42 so I removed the torx pin and attempted to push the other end out. No luck so I put the screw most of the way in and tried to tap on it with a torx bit and a hammer. Unfortunately, the torx pin bent before the other side even moved a millimeter. Now, haven given up on removing the latch, I need a replacement torx pin. Where can I get one and what should I expect to pay?
