If your 420HC was damaged I think they would replace it with a 420HC, but otherwise I think you need to buy the ATS-34 model! It is worth trying I guess, but two Buck rush's at home wouldnt be bad either!
I had a folding alpha hunter that the blade edge dinged up on, it was the 420HC, they would replace the 420HC but wouldnt upgrade the blade. Maybe that has changed...
I went and bought the "upgraded" model. (I needed it really)
It may be just as affordable to buy the ATS-34/154CM version!
Is the 420HC damaged? I know the blades are replaceable, BY Buck![]()
Good luck!
