- Mar 1, 2010
When I sharpen my knives at a more acute angle on my aligner is that reprofiling or is that just making a back bevel? Or does reprofile mean that I have to hit the whole secondary bevel?
Perhaps I am off base?
I use the term "re-bevel" when I change the geometry of the bevel. This can include any of the following:
Changing a V-bevel to a convex
Changing a Convex to a V-bevel
Changing the angle of a V-bevel (perhaps taking a 30 degree inclusive bevel to a 20)
Grinding a bevel out to eliminate secondary bevels or micro-bevels (for example a factory edge that came with a primary edge bevel of 30 deg inclusive that has been touched up several times at 40 degrees thus creating a secondary "micro" bevel).
To me "re-profile", means you are changing geometry of the entire blade. If you have a saber-grind or hollow-grind knife for example, you must re-profile the blade if you want a full flat grind. Additionally, some will keep the general geometry but re-profile the blade so that it is thinner at the widest point for better cutting performance, or to achieve a zero grind (or at least something closer to zero than stock). As pointed out above, as a knife gets used up the bevel gets thicker and thicker shoulders. Some will re-profile the blade to reduce the shoulder width. Regardless, to me "re-profile" is understood as something much more involved than altering the area of the blade withing a few mm of the cutting edge.
As I said, perhaps I am wrong?, but I have adopted the view that you can re-grind a bevel or a blade. Re-grinding a bevel is a much smaller task than re-grinding an entire blade (thus re-profiling it). Admittedly, the lines get sort of blurry when your bevel starts to extend into a significant portion of the blade.
I am interested in what others think about this...
I don't have any problem at all in making a distinction between reprofiling the EDGE of a blade or, as unit described, reprofiling the entire blade. I think the term 'reprofile' can be applied either way. To me, it's about significantly altering the shape (geometry), but to lesser or greater degrees. The term 'profile' refers to the outline or shape of something. So, for me, 'reprofiling' just means that the outline or shape is being altered. That could be the shape of the whole blade, or the shape of the edge alone.
So, to unit, I don't think you're off-base at all (or wrong). I believe you're just thinking about it on the larger scale of the whole blade, whereas I'm applying the term to the edge alone.
That's my two-cent opinion on the matter...![]()
Thanks for your opinion. I think it is a valid discussion and your interpretation seems logical.
I guess the term "re-profile" should be accompanied by a classifier. ("bevel re-profile" or "blade re-profile"). Sort of like "20 degree edge" needs to be classified with "per side" or "inclusive".
Leave it to a knife nut (me) to analyze the minutia LOL.
