- Aug 1, 2013
For the past few weeks I've had the Gayle Bradley I couldn't be happier for its fit and finish and overall design. However I wanted to test the limits of the M4 steel and maximize its cutting ability. I ground the secondary bevel to around 9 degrees inclusive and added a tertiary mircobevel of 30 degrees inclusive to add robustness to the thin edge.
Before I thinned the edge:
[/IMG]
[/IMG]
While grinding away metal:
[/IMG]
I duct taped the majority of the blade to retain its satin finish and geometry, but later removed it when working with finer stones. (Warning: duct tape clogged my Arkansas stones, fortunately the stones used were inexpensive)
[/IMG]
My Spyderco managed to bite me while sharpening. Yes, I like to live on the edge and use my Sharpmaker without the safety rods.
Here are some shots of the GB nearly finished, not quite mirror finished, but I'll be working on it.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
It's penetration of wood with 45 degree pushcuts has greatly increased, it would probably do even better if I had ground off part of the hollow grind shoulder. Another day...
[/IMG]
It fared favorably against grinds (scandi, convex, and flat) that would normally dominate hollow ground blades, because of it's new thinness. Surprisingly, wedging wasn't too big of a problem.
[/IMG]
Show me any alterations you've made to your blades, whether they increased performance or not. I'm sure glad I did!
