- Oct 28, 2018
What's a good fast cutting stone for reprofiling, right now the fastest cutting stone I have is the 220 grit plate for my worksharp GSS but I feel this is too slow for severe edge damage
ThanksCoarse side of a two-sided SiC oilstone is fast for that. For example, Norton's Coarse/Fine Crystolon is rated at 120-grit on the Coarse side.
The bigger factor for reprofiling is the size of the stone. Portable or 'field' size stones are usually too small to be very fast at such jobs, although it's doable (just prepare to be at it for a long while). A bench-sized stone of 8" x 2" or greater size makes fast grinding a lot easier, sometimes even with relatively finer grits of up to ~ 600 or so (in diamond), or something like ~ 320 in SiC (the 'Fine' side of the double-sided Crystolon stone). Obviously, the type of steel and blade size/thickness play into that too. So, with a big & thick blade in very wear-resistant steel, choosing a big stone in pretty coarse grit would be wise.
Totally.A bench-sized stone of 8" x 2" or greater size makes fast grinding a lot easier,. . .choosing a big stone in pretty coarse grit would be wise.
I bought an ACE two sided 8" stone about a year ago. It was grey and I believe is AlO2 and not SiC as I had hoped it would be. It's a decent stone, but I'm not a big fan of it so far. Like I said, I just need to order the Norton Crystolon or that Manticore!
Brian.
I suspect the black SiC stones are sent to fill orders when the warehouse is out of the grey aluminum oxide stone. So, it's by luck you see
one on the shelf in a store. In my area I have 5 of these stores that carry these stones. So, I just keep checking until I see one, then purchase it. DM
When I want to get really crazy (meaning take a significant amount of metal off a flat surface like the back of a chisel) I totally go for Alumina Zirconia.What's a good fast cutting stone for reprofiling, right now the fastest cutting stone I have is the 220 grit plate for my worksharp GSS but I feel this is too slow for severe edge damage
