- Feb 25, 2011
Hello All,
I am designing a tool to maintain high-end kitchen knives that are in frequent use. I have drawn up plans for a base that has many holes in it to hold a pair of honing rods at various angles for different edge bevels. My current design has pairs of holes for holding the rods at 15, 17, 19, or 21 degrees per side. It is designed to hold the rods in an X-shape while the user gently draws the knife edge along the top of where the honing rods cross (like those little pocket pull-through sharpeners, but on a much larger scale). I am planning for the tool to have two sets of honing rods to use with it. One set will be a fine alumina ceramic for a very gentle sharpening action as the blade is hones and the other set will be glass rods in the tradition of HandAmerican's borosilicate glass butcher's steel.
First questions: what do you think of this concept? Do you have any suggestions for improvement?
Second questions: what kind of glass should be used for the glass honing rods? Should the glass rods be smooth/polished, or should they be "frosted" by tumbling them with some SiC grit?
Before researching glass types, I was under the impression that HandAmerican chose borosilicate glass because it is a harder material than regular soda-lime glass, but it turns out that this is not the case! Borosilicate glass is quite a bit SOFTER than regular glass, so is is best to use soft boro glass or harder fused quartz glass or soda-lime glass. I can also guess that HandAmerican chose the boro glass for thier butcher's steel because it is less brittle than soda lime glass, rather than for any benefit in it's honing ability. If this is the case than I see no reson to use more expensive boro glass when soda-lime glass rods are available so cheaply.
FYI, these are the Knoop Hardness (kg/mm^2) values I have found online for glass products from various manufacturers:
Borosilicate Glass : 448-481 (softest)
Fused Quartz : 487-600
Soda-lime Glass : 565-605 (hardest)
