- Apr 20, 2010
Could someone please post a side by side of the code 4 and the Endura 4. And your opinion as to which is the better overall knife.
Thanks
Thanks
Thanks
Both are great knives from great companies, and designed for the same purpose but with different perspectives on what makes a good knife.
The Code 4 is a much stronger design, and though both knives are very smooth on the pivot out of box, the Code 4 is more so.
Both knives offer great ergonomics. The Endura's are better, in my opinion; it's a lot less likely to slip out of your hand due to the awesome jimping and bi directional texturing.
The Code 4 is very lightweight at just over 4oz, but the Endura is lighter. I believe it comes in at around 3.5oz.
The Code 4 is available in CTS-XHP steel, whereas the Endura is VG-10 or ZDP-189, unless you count the sprint runs. Mine is the Super Blue sprint run.
Fit and finish is a little better on the Code 4; the only meaningful difference I could see between the two is that my Code 4 is perfectly centered, whereas my Endura is not.
Prices are very comparable, though the ZDP-189 and sprint run Enduras are going to be a little more expensive than the Code 4, which tends to be a little more expensive than the base VG-10 Enduras.
Either one should make you happy. Both companies offer wicked warranty services, so there's no need to worry about the quality of either knife upon purchase.
Great notes KwonKang,,
Great response. I have nothing to add except the idea of the endura-like Pacific Salt if he wants lighter (no liners) and 100% no rust. But in Colorado it may not be necessary. Also note the blade shape is a bit different.
I recommend the E4 FFG ZDP-189 with super-splicer blade. Bought mine a month or two back from an online auction. The true super steel gives it amazing edge retention. Weighs 68 grams which for a 3.75 inch blade is pretty decent considering what it gives you in performance. It did take a little bit of getting used to with the design and plastic handle but now I'm sold. The bidirectional patterning on the scales gives it great grip. I haven't owned it for very long and apparently one of the drawbacks is that its difficult to sharpen so I'm currently looking into where I can get a better sharpening system if anyone has any ideas?. First time i've owned a Spyderco but really pleased with it overall.
