Request for BM Mini Ambush Review
I've searched the archives and haven't found any reviews except a first impression. Has anyone used the knife extensively enough to post a review? In depth is great but even a quick one is just as good.
Thanks in advance.
Bear with me, as this will be the first review that I've written. I can't remember exactly, but I believe I've had this knife for about 6 months or so, and I really like it. It has a little more class than my Ka-Bar Dozier thumbnotch folder, and I usually carry mine in more sheeple infested areas.
I like the tip-up carry, and the clip has good retention. The clip is set up for only tip-up, interchangeable to right or left side. This knife is quite thick for the size, about 1/2 an inch or so at the butt. It has a serrated thumb ramp, although the knife is a little small for my hands to accomodate a full saber grip (FYI, I wear large gloves, have fairly large hands). The handle does lend itself well to hammer and icepick grips, and the ergos are nice. The thick handle feels more comfortable to use for longer periods that thinner FRN handles I've used. The handle is also serrated on the rear of the butt, and the underside at the butt and towards the blade as well. They seem to add to grip security but nothing quantifiable. The lanyard hole seems quite small, I would think even a shoelace would be difficult to thread through, if lanyards are your thing. The thumbstuds are ridged, similar to the Kershaw Vapor II, and quite "grabby", if a little difficult to use, depending on opening technique.
The FRN handle doesn't feel cheap like some knives, owing to the dual steel liners I'm sure. I haven't beat the hell out of the knife, but I do have great faith in the Rolling Lock that this knife utilizes. It tolerates numerous hard spine whacks and palm pressure to the blade spine.
I haven't quite decided what to think about the In-Draft system. On the one hand, living in Canada, having a pocket knife with a detent as strong as this one makes it difficult to flick and thus safer legally speaking. On the other hand it can take some time and practice to open the knife quickly and safely if you're not used to the mechanism. I prefer a sort of abbreviated thumb flick myself.
Edge holding seems to be on par with other AUS8 knives that I have used, perhaps a bit better with this knife. Maybe Benchmade runs their AUS8 harder than CRKT, Timberline and Ka-Bar. I'm sure someone with more knowledge than I can comment on that. It took me longer to sharpen this folder than knives with similar steel, so I use that as a frame of reference. I do know that my Mini-Ambush takes a great edge and holds it well. Touch-ups have been quite simple as well.
I do have a complaint regarding the thumbstuds however. The thumstuds on this knife are huge. They stick out 3/16" on either side of the blade. It wouldn't be an issue were it not for the reprofiling it with my lansky. It took some creative work to try and sharpen around those monstrous thumbstuds. Even touch-ups on a ceramic crock stick were difficult. As a frame of reference, I reprofiled the edge to 30 degrees inclusive, 15 per side to take advantage of the nice flat ground blade. Maybe the factory edge is catered to the protruding thumbstuds. It's not a huge problem, but I feel the knife loses some points overall for that.
To sum up my rambling overview:
Pros:
Nice ergos, comfortable handle
Good blade steel
Solid lock
Good blade shape, lends itself well to slicing
Tip-up carry, if that's your thing
Cons:
Thumbstuds, can be awkward to use and are very large
In-Draft System, can be mitigated with practice. Good for the legally paranoid but hard on the thumb.
Overally,I would recommend the Mini-Ambush to anyone interested in it. I like mine, and I'm sure I could grow to love one day. Mine sees a lot of pocket time, but unless I bring my folders to work they generally don't see much hard use. I myself am more of a low speed operator, and my Mini-Ambush works very well for me.
Not to cause a stink on the Mini, but i will toss in my point of view.
I bought a Mini-Ambush a while back, one of my first BM's, i loved the look of it, although, i started loving it less once i got it home.
The Rolling-lock,Only on the Ambush's is very different then the Axis lock, and my right thumb can tell that from the first day.
When going to flick mine open, i found you could not let your thumb follow the stud, as sometimes if the inertial opening wasn't fast or hard enough,the blade had a idea to either stop or re-close, with your thumb still in the path.
It bit me once, then i started researching the lock system a little bit, and found it was a truly one of a kind type by them,only used on the Ambush's.
After generally fondling the unit for a couple days, i realized that my grip might be a problem with this lock, my thumb naturally wanted to rest on top of it when doing light cutting chores and would sometimes disengage it, no fault of the knife itself but more mine.
A couple of times the rolling lock did not completely engage, maybe was a weak flick, but this with the "Do not follow the stud" thing does not feel %100 in my hands.
This made me lose some confidence in the lock, and sleep, in the end i have released it from my possesion and returned it, the dealer completely understood, local brick an mortor place, the girl there had a hunch it might be a tough sale to a knife nut over an Axis. She has no less then 4 knives on her each time i visit.
Do not let my rant stop you though, the unit is still a sweet knife, a little thick as mentioned,but just not for me.
Peace
WR
