Rescue Knife - where do you stow it?
I'm considering a rescue knife (seat belt cutter and glass breaker) for the car. Where do you keep them? "In the pocket" is a bad idea if the seat belt is stuck, crossing the lap. Loose in the car is a bad idea since an accident could throw it anywhere.
In the console?
On a lanyard? (Lanyard tied to what?)
i have a resq me and i keep it in the sunglass holder built into the car as its in easy reach and my sunglasses never fit in there anyway.
Is a seat belt really that hard to cut that it needs a special knife? I've never tried to cut one before...what is the main purpose of a rescue knife? And please don't say rescuing...
My Benchmade is a really good one made to cut any seatbelt even the heavy race car ones .I decided that the pockets in the door of my truck is the best place. It can be secured there . I also have a large automatic center punch for taking out the windows. Understand that windshields are very tough so don't try them. Use side windows but at the lower corners .
You are correct about loose items in a auto collision. They can fly every where.
I have more than one knife. The first rescue knife stays in my aid bag. Second knife is in the tool knit of my motorcycle but it should be in the tank bag. Third knife is in the glove compartment of my wife's car. I have carried one in the center console of her car but found it difficult to get at with the seat belt on. If my wife would allow, I would secure the knife to the door of her car with a lanyard and some Velcro.
I would recommend that you spend an afternoon testing your rescue tools on some damaged autos in a wrecking yard if possible.
Bring a pair of work gloves with you.
When a vehicle is in a collision, especially a roll over, any thing loose will fly all over the place, If your cutter is loose in a door pocket or dash compartment, clipped to a visor or seat belt before the collision, it won't be there after the collision. If it is your glove box and you need it, you won't be able to reach it if the seat belt is stuck.
A dedicated seat belt cutter is preferable to a knife. Seat belt cutters have their cutting edges on the INSIDE of a curved sharp edge. No point to jab your belly as you try to cut the belt.
Paranoia is your friend. If you have only one seat belt cutter in your vehicle, secured in the driver door pocket, and you are incapacitated, your passenger, if you have one, won't be able to reach it. So always have two. A third one or two in the back seat if you are a really paranoid preparedness freak. :D
The best place to secure it is in the center console of your vehicle, if there is one. 2 reasons - First, it's possible that a door pocket might be inaccessible in the event of a T-bone collision. The second - Passenger or driver can reach into the console compartment easily. If there is no center console, you can use a door pocket. You just have to secure it properly. I have one in BOTH door pockets of the truck (no center console) in the event my passenger has to use it.
For my cars, I secure mine in the center consoles. For the securing, I used a long strip of 2" wide velcro.
First, I superglued a piece of velcro to either side of the seat belt cutters.
Then I glued one long side of the velcro to the inside wall of the center console. Actually I did this twice - a cutter on both sides of the center console so both people in the front can access a cutter if time is short for evacuation of the compartment.
Then I stuck the cutter to the velcro.
I sewed a piece of scrap leather to the other half of the long piece of velcro to have a large "pull tab".
Then I stuck the other long velcro half to the cutter and pressed the tails down firmly on the two "tails" of the velcro sticking out either side of the cutter. This way if you have to pull the tab, the knife either sticks to the piece you pull of or it stays stuck to the part glued in. Either way, you have a cutter.
All this ensures that the cutter will be exactly where it should be in the event of a collision. Easy to find, even in the dark. If the vehicle is inverted, when you open the console, the cutter won't fall out and get lost. If it weren't secured, it could just fall out or be buried under all the crap that accumulated in the console an hard to find even if not inverted.
For the door pockets, you do the same, just mount it where ever a large flat spot is available.
Lots of great ideas here.
By "rescue knife" I mean one with a hard point for breaking windows and a reversed (inside out?) blade dedicated to safe seat belt cutting.
You will find that a spring loaded center punch works better than the hard point on the back of most rescue knives.
Yes and that's because you don't have to swing it !!! It's hard to swing if you're under water or have injuries that prevent a swing.Get a large one .
any sharp plain edge knife will cut a seat belt like butter. The point of the designated seat belt cutter is that it is designed to not cut the person (the blade is guarded) that your trying to free.
Thanks guys for mentioning the seat belt limiting movements when trying to grab the cutter.
I have a spring loaded glass breaker on my car keys but wouldn't be able to reach it when the belt pulls me back into the seat during an accident. Same goes for the little compartment next to my left knee which contains a little knife. Couldn't reach that too when pulled back unless I manage to wiggle my left arm out.
Gotta rethink it a bit and there are some great ideas here.
Thanks again. :D
I just carry my regular knife. Any knife will break a window. Put the point on the glass and hit the end of the handle. Only one arm working after the wreck? Just swing it at the window. It'll break.
As for the "rescue blade" thing, I just figure as long as they're not in the car burning alive or drowning, they won't mind a couple stitches if I poke em!
I just stick with my ZT620 in my pocket where I know it's at. I'll take my chances on being able to deploy it and escape the clutches of death.
I honestly most of the time when I am out of my home have a minimum of two pocket knives on my person. I honestly see no reason to keep a rescue knife stashed in my vechicle, when I have two on my person. The exception is going and coming from my community swimming pool. Then I am down to one knife in my fanny pack that will accomplish any rescue task with ease.
I carried a window breaker like that for a year or so but it kept filling up with pocket lint. I was afraid it would be non functional when I needed it.
+2 Bright red Resq Me on my car key and the wife's car keys. Just in case we're banged up bad. Works even with lint in it! ;)
