Christian, good idea, just make sure you add some kind of filer or have enough texture on the mold to make sure the handles are slip resistant, cause this stuff is really slick..
As far as making the molds go, you can make a master that you want copied into a mold. Then there are several ways to go about making a mold, if you plan to use the mold over and over, I would suggest a silicone or ruber mold, that way all you do is let the resin cure then peal everything off...if you ony want to do it once, take your master handle, make sure its sealed. Then take some plaster of paris, and make two parts that go over each half of the handle... then coat the plaster molds with vaseline, lightly, and pour in the resin..
instead of using holes through your tang, I would suggest running a couple peices of pinstock through your tang, not long enough to extend through your handle but just to float in the middle, so that when your resin sets you have hidden pins holding the tang more securely..
One more idea, instead of using clear resin try some good old fashioned fiberglass resin, cause if you are gonna color it, you might as well start with colored resin that doesnt cost as much... fiberglass resin is like 20 bucks a gallon the clear stuff is like 40 and it is softer once its cured..
If you have any other questions or ideas, and you dont wanna post them, send me an email and I can set you up with mold supplies and everything else..
Alan Folts..
