- Apr 3, 2011
So I found this MSDS on Norplex's Micarta which states "If heated in excess of 300 deg C, products of combustion could include: CO, CO2, phenol and hydrogen bromide gas."
And I found this MSDS for G-10 which states "Carbon dioxide, carbon monoxide, bromine and other hazardous gases may be generated under normal processing conditions."
So in other words, particulate filters alone do not offer adequate protection when grinding these materials if you get them really hot.
I'm trying to look at filter cartridges and which filter ratings are needed for both of these materials. Specifically for the 3m Versaflo (TR-600), under page 13 (here) you can see the available cartridges, all of which have different ratings. I also found this 3m Filter Guide that tells you what the filters need to be rated for which acids/chemicals/gases. It looks like the hydrogen bromide and bromine gases would be filtered out with an OV (organic vapor) cartridge, but the phenol gas (which is the base for formaldehyde??) would need the formaldehyde filter specifically.
Any thoughts/recommendations on this?
* Update: I spoke with Norplex's safety officer and he stated that as long as you keep the micarta under the 300C temps then the Organic Vapor cartridge should be fine.
