I have recently cleaned up and restored an old east wing hatchet. I used rust remover, grinding wheels, and sand paper. I think the edge is too soft, how can I temper it? Can it be done at this point?
I believe that it got too hot during the grinding process. Would that cause it to soften?The short answer is, not without wrecking the handle. At the factory, all the heat treating is done before the handle is installed.
Did it go through a fire or other heat event that changed the original hardness? Can you use it as is?
Parker
It can easily be done. But first is it a 'Estwing' with a metal handle? DM
