- Jun 29, 2020
Like a jackass I broke off the tip on my BD1N Manix 2 by hitting a plate with it. I've been working on re-sharpening the tip using a sharp maker with boron nitride rods, but can't quite seem to get there. I have done a *little* regrining the spine of the blade near the tip, but I don't want to change the geometry *too* much.
Thus far my method of tip refurbishment has been: sharpen as normal with the corners of the rods, being *exceptionally* careful not to ride the tip off the edge (I have rounded the tip sharpening with these rods before). When I switch to the flat sides I spend extra time removing material at the tip. The tip is definitely better than it was, but not as good as I want, and definitely worse than the factory tip.
Here's what the blade looks like right now:
Here is a close-up on the tip:
As you can see it looks ok from a distance, but it definitely is not anywhere near as sharp as it was out of the box, even though I have the edge of the blade sharper than the factor edge was.
Should I just keep doing what I'm doing? Are there any technique issues I'm possibly not paying attention to? Do I just need to use different tools to accomplish this job? Should I grind down the spine a little more? Any help or feedback is appreciated, thanks.
