Just wondering if it's possible to recycle or get multiple uses out of PCB etchant for acid washing blades. I wouldn't want to dump some of the scum back into the container, but it seems like there's a lot of clean acid left unused.
Chris "Anagarika";12665473 said:There's only so much acid that can react with the metal, so reuse is possible, but it's finite and will give diminishing return (i.e. weaker/slower the next time).
As exaggerated and simplified example: a measure that's being used now contain 10 gr of pure acid. For each blade (assuming same size, surface area & material) it takes 1 gr.
The next time it's used, the acid is only 9 gr of same liquid volume (=diluted), so it might take slightly longer for the next 1gr to react fully, as each volum/surface contact will have 10%less acid.
Hope this helps.
