JPD1998
- Oct 18, 2004
Id been interested in CRKT Lake's P.A.L knife for a while and even considered buying one a few months ago, but the price was always the deciding factor. Well this past week I got an opportunity to buy on at a very good price so I picked one up.
Some stats from CRKT:
- Blade Length: 2.75" (7.0 cm)
- Thickness: 0.14" (0.35 cm)
- Steel: AUS 8, 56-58 HRC
- Handle length: 3.75" (9.5 cm)
- Overall length: 6.625" (16.8 cm)
- Weight: 4.9 oz. (139 g)
I really like the marriage between modern and traditional styling. Also the open design and the tank-like build is really appealing for a small knife. While this knife is marketed as a pseudo Gentlemens pocket knife, it is a little on the heavy side and probably would be better if designed with a pocket clip instead of the included leather pouch. The leather pouch is really too big for inside a pocket but it has a belt loop too.
Every part of this knife is overbuilt and the result is a very stout little folder. Some might not like the thickness and weight of this knife, but it looks like a quality product without being excessive. The blade size and shape would make this perfect whenever a larger knife is needed but not practical to carry.
The button lock is very cleverly designed, the single post serves as a lock and also has a notch cut out to keep the blade closed. The lock post also serves as a stop pin.
The blade has two large nail nicks, for left or right handed use and theyre deep enough to be used as a stud.
The fit and finish is excellent, lock-up is solid with no obvious blade play. I could only find one nit picky thing. There was a burr sticking out where the bone handle was fitted to the frame, I almost cut myself, but it was easy to remove with just my finger nail. The blade came very sharp, but not razor sharp and the edge is a little thicker than some of my other CRKT knives.
The bottom line is Im quite impressed with this knife. Considering I bought two other knives over the last month and only took time to write about this one . well I guess subconsciously I like this one the best ( but I wont tell the others).
The picture is from CRKT
