Review: Emerson & Tarani Karambits (long)
Klesk
I just got my Tarani Master's model, so I wanted to do a quick comparison before I sent the Emerson off to Las Vegas.
First I'd like to say that I am not an operator, an LEO or a martial artist, just a guy who likes knives, so my comments will have to be taken in that light. Secondly, I'm not a photographer, so please excuse the quality of the pics. On to my little review.
GENERAL APPEARANCE Both knives appear well made, with no obvious flaws. Both lock up solidly, with no blade play when open. The handles on the Emerson are more comfortable, with a less agressive pattern on the G-10, and rounded edges. The Tarani has very sharp checkering and the outside edges of the handles are just "broken", not rounded like the Emerson. The handles of the Tarani remind me of those on the Buck/Strider folders. As you can see in the pics, the Tarani is somewhat larger when closed, and has a larger ring. Open, they are very similar in size, though the Tarani has a much more pronounced curvature.
HANDLING Both knives stick out of the pocket quite a bit when carried, the Tarani more so than the Emerson because of the placement of the clip. With a pair of walking shorts, where the outside edge of the pocket is fairly far down and back, the Tarani was kind of annoying, as it would hang up on things like my seatbelt.
Both knives open smoothly, though the Tarani seems like it would be more difficult to wrist flick or "Brownie Pop" open, owing to the lock design. The Tarani uses a front locking bar which, by design, puts the most pressure on the blade in the middle of the opening motion. The Emerson, by contrast, uses a locking liner which exerts most of its closing force on the blade while it is closed. Thus, with the Tarani, opening requires the user to overcome the closed blade, then the camming action in the middle of opening, before the blade will fully open. Many in the Karambit.com section of the forums have reported that they succesfully use a wrist flick or "Brownie Pop" to open the Tarani; all I am reporting on is what I have experienced.
Because of its front-lock design, the Tarani seems more secure in the saber grip. Your thumb would rest on the locking bar, actually pushing it harder into battery. The Emerson has a locking liner which may not be 100% secure during twisting or other blade manipulations.
MINOR OBSERVATIONS The blade grind on the Tarani is quite different from the knife in the ads and on the website. My knife has a secondary grind on the top/front of the knife, which allows the tip to be thinner. The edge bevel is also ground differently, being farther back towards the handle. I like this as it gives about another 1/2" of cutting surface, as compared to the knife shown in other photos. Of course, this feature totally negates any possiblity of "choking up" on the blade for fine work, despite Karambit.com's portrayal of the knife as a utility tool. ;)
MAJOR OBSERVATIONS The Tarani is only the second of the hundreds of knives that I've handled that I didn't need to sharpen at all out of the box (the other is the Spyderco Ronin). The Emerson is not as sharp, and has that pesky chisel grind that I dislike so much. Unlike other Emersons (the production CQC-8 comes to mind), the Karambit's blade is flat on one side, which makes regrinding to a "V" grind impractical.
The one thing that really bugged me about the Emerson is the "unfilled" ring. The Tarani has a steel backspacer that continues back and fills the ring. The Emerson makes do with a short backspacer that terminates just before the ring. For one thing, a knife at this price point needs a steel or aluminum backspacer; that black plastic easily destructible stuff just doesn't cut it. For another, because of the thin liners on the Emerson, I can easily squeeze the end of the rings together. Whether or not this is an issue for professionals, I am not in a position to comment.
FINAL THOUGHTS I like the handling of the Emerson better, as it is a little more compact, both open and closed. On top of that, the texture of the handle is a little more hand and pocket friendly. Also, the distance from the ring to the opening hole on the Emerson is slightly less, just enough to make it easier for me to open the knife with my pinky finger in the ring. The Tarani, however, has a conventional blade grind, which I prefer, and just seems better built overall.
The pricing of these knives makes it difficult to directly compare them. I paid full price for the Tarani ($245), though I have seen it on the web for around $195. The Emerson lists for $235 or so, but can be had at web stores and Ebay for around $160. To complicate matters, there is a Tarani Journeyman model that sells on Karambit.com for $175 - I would assume that one could be had for less, but I haven't seen any for sale yet. The Emerson may compare more favorably with the Journeyman as they use the same blade steel (154CM) though the Journeyman makes do with "plastic" handles instead of the Emerson's and Master's models' G10.
That's it, I hope some can find this useful.
im gonna get an emerson one soo, along with the tapes, the main reason why im gonna buy the emerson is that u could pull it out a hell of alot fater than the tarani cause of the wave
Klesk:
Good review and observations about both.
You may also find the larger ring on the Tarani an asset once you get the "drills" down with going from retracted to extended grip.
My journeyman "pop"s open much easier than the Masters model [ as reported at www.folders-r-us.org , probably due to less resistance on the blade by the handle materials.
Good job and congrats on their acquisition to your collection.
Brownie
I just received an E Combat Karambit, and was most disappointed. For starters, the wave would not deploy . The point was so shear , , I doubt it would hold up in long term and I would not trust it in a hostile situation. The liner lock, is not strong or stable enough for a combat situation. I have heard all this hype about how awesome this E Combat Karambit is. while it is mean and sharp ,I doubt this knife in its present form would be something you would carry around
as an edc.
The Knife needs to be reworked bigtime!!! For starters, the lock needs to be designed along the lines of an Axis lock. the blade needs to be rethought out. (way less shear) Oh and another thing why does Emerson emphasize the use of Phillips screws and not Torx screws. ?
Pardon my 2 cents, I think Im going to have to build a better moustrap
Shear? I can assume you might mean that the tip is thin or pointed, comparatively, but your description is a little vague.
Waves are in no way guaranteed to deploy - how the user trains to achieve consistency with the type of clothing they must restrict themselves to will help. Liner locks in general have their detractors, but Mr. Emerson's aren't known to be poor quality.
His choice of phillips screws was to improve owner maintenance, as most knife guys didn't own Torx drivers at the time it was introduced. Torx head screws are no guarantee of quality, they're just broached with the star, and plenty of Jeep owners will tell you they are a pain and another thing to replace. My experience is they are no better than phillips - the star will strip out, a phillips will cam out, which is what it is designed to do, limit torque on installation. Cadillac first used them on the assembly line in the thirties, before clutches on air powered tools were incorporated.
Anyway, odds are the average Emerson owner has a phillips driver on his SAK in the field, not a Torx.
Your better mousetrap does sound like a seller. A tough, Axis locked, high tech Kerambit would be the snitz - as a one-off. Heaven help you if the BM and Emerson fanboys catch wind of any design knockoffs for profit. :D
I personally believe the torx head is a decided improvemnt over the phillps head. The reason being many more points of contact , means better leverage and more precision over the screw. The torx head driver is availble in most hardware stores. Nice historical reference to the origin of phillips head. Actually Phillps did not invent the Namesake. The original inventor was a chap named J. P. Thompson.. JP sold the patent to American screw company who marketed it successfully to The AUto boys.
Anyway, by shear, I mean the point is just to needlenosey. The point needs to be better reinforced.
The wave, while , a way kewl concept, needs some more improvement. I agree, practicing with the wave would vastly improve performance to the seamless level. The problem that arises is , performance of the wave, varies with which pair of pants you are wearing. I agree if you can get the wave to work , with a given brand of pants or BDU , great tactical advantage. The reality , is you limited
in what type of pants you can wear. The wave needs to be configured, to work seamlessly with any pair of pants.
I fail to see why any manufacturer would still use a liner lock(no matter how well made) with the advent of far superior lock mechanisms. Liner locks to my way of thinking belong in the museum.
I have not given up on the Karambit, cause i think it is a very meritorious knife.
I think I will look into a non folder version . In the meantime , I will be busy at the design table. I welcome anyone to collaborate with me.
Regards
Barry
My 2 cents worth
i had a tarani master model and just hated the thing, only thing i did like was it was right at the beginning of the k'bit era and it was easy to sell,
