- Mar 15, 2000
This Esbit Solid Fuel Cookset makes a lightweight, compact package for heating water. Fit and finish on my set is quite good. The stove base, built to receive a hexamine solid fuel tablet, nests perfectly inside the lidded cup with plenty of room to spare for several tablets, a cleaning sponge, etc. Moreover, this base has a large cut-out on one side and thus, in a pinch, could be pressed into service as a twig stove. The cup easily hold two cups of water and has several desirable features that include: pressed-in volume measurements from 200-400 mL / 8-16 oz., fold-out handles with insulation, a small pouring spout, and a well-fitting lid that also features a folding handle. The set comes with a nylon mesh bag that makes for easy carry, and when nested inside the bag, is roughly the size of a softball.
I ran three trials in testing this stove. All used MPI/"Grabber" brand hexamine solid fuel tablets. Each trial used 2 cups of water that was 36 degrees at the outset. All trials also employed a small piece of aluminum foil in the tablet recess for easier cleanup.
Trial 1: With a covered cup, I used one solid fuel tab laid flat in the tablet recess. I peeked in on the water at 7, 9, 11, and 13 minutes. The solid fuel tablet burned out completely around the 13 minute mark. Water was hot and steaming, but it never came to a boil.
Trial 2: With a covered cup, I used one solid fuel tab laid flat in the tablet recess. I kept the cup covered and looked in at the 11 minute mark as the solid fuel tablet's flame was starting to weaken. Again, water was hot and steaming, but it did not boil.
Trial 3: With a covered cup, I used two solid fuel tabs standing side-by-side on end. This tactic (a) generated more heat, and (b) put the flame closer to the bottom of the cup. The flame did blossom outside of the stove base more readily, and for a moment during the initial burn, I worried about melting the plastic insulation on the handles. No damage resulted, however. The water began to boil around the 10 minute mark, and when checked at the 12 minute mark, the water was at a rolling boil. The tablets totally died out around the 14 minute mark, and the rolling boil only lasted a short while.
Conclusions: With one tablet, this Esbit solid fuel set is best suited for heating water that is already treated. In the first two trials, water was sufficiently hot to make hot drinks or to constitute freeze-dried meals. As my third and final trial showed, the Esbit set can boil water, but this result required two of the hexamine tablets. The tablets do burn dirty and produce a lot of soot. Thus, a small piece of foil works well to limit soot accumulation in the stove base, and I recommend carrying a scrub sponge for clean-up of the cup. Otherwise, a paper towel or bandanna could be used to contain the soot and prevent it from rubbing off inside a pack. At just under 7 ounces (not counting fuel, sponges, etc.), the set is a light option for day hikes or for overnighters with freeze-dried meals. However, I would not rely on this stove for more traditional cooking unless I were using it as a twig stove or unless I had a lot of solid fuel tabs at my disposal.
