- Oct 3, 1998
Here is a review of a sample of one of the newer Spydie Military models. These are the knives advertised in the December 1998 issue of Blade magazine and the January 1999 (yikes!
) issue of Tactical Knives magazine. Hope you all enjoy!
C36GSE MILITARY
Having had an opportunity to road test a Military model (ATS-34 bladed) from the original production run about a couple of years ago, I discovered this to be a great heavy-duty large folder. After the company made improvements to this model over the brief amount of time that the knife has been on the market, I was eager to road test the knife again. I was especially looking forward to revisiting the Military because of the CPM 440V steel. I've had experience with about every steel used on production knives, and this was looking forward to experiencing 440V.
Here are my observations and highlights of the C36GSE:
THE BLADE
· CPM 440V is the toughest steel I have used to date.
· Fully serrated blade - nice and very sharp out of the box.
· The curve of the cutting edge makes the knife an excellent slicing tool.
· Notched thumb rest and choil make it easy to choke up on the blade for precise control when needed. This grip is very secure.
· Laser etching on the blade itself provides an attractive alternative to the standard location on the tang.
· Another aspect of the blade I found favorable was the short (1" long) plain edge section at the very tip of the blade. This short plain edge makes it convenient to do some precise cutting (opening boxes and other slicing and nipping jobs). So, this fully serrated blade can perform some tasks that a plain edge blade can tackle. Makes the knife more handy - kudos on not really fully serrating the blade!
THE HANDLE
· G-10 handle is of nice texture. Not too harsh like other manufacturer's G-10. There is enough texturing to provide a secure grip. The perfect texture!
· Love the clip's attachment points to the handle - leaves the pivot free for adjustment.
· The clip's curvature is unique. Matches that of the handle. I like that extra touch!
· The curves of the handle accommodate the user's hand very nicely.
· Torx assembly screws on both sides of the handle - strengthens the handle for sure.
· Lock release recess and blade hole are larger than normal for good purchase, even with gloves. Hence, this will be a good knife for those who wear gloves. No need to stop and take the gloves off to open/close the blade. I used am able to wear my work gloves and open/close the blade as if I'm not wearing any gloves.
· Notching on the lock bar, a nice touch. To give a sure purchase with or without gloves.
· Minimal spacer - promotes ease of cleaning/drying.
· Overall shape of the handle conforms to the user's hand. No hand movement forward or backward.
PERFORMANCE
The Military is very easy to carry around - a large folding knife without the extra weight or bulk as with other folders on the market. The knife was carried clipped to the top of the right front pants pocket and inside the waistband. In either location, there was no discomfort.
To tell you the truth, I had fun with the cutting tests! The CPM 440V steel withstood everything I threw at it. With all I did to it, I managed to slow the edge down a bit but not seriously dull it. The factory edge is very easy to maintain. When the edge started to dull slightly (thus, requiring more pressure applied to the blade to make the cut), I touched it up on a steel. After a few minutes of steeling, the serrations zipped through anything easily! After a couple of weeks of use, the edge could no longer get by with just simply a few swipes on the steel. Therefore, the blade was sharpened with a DMT Diafold serration hone in coarse grit. The serrations turned out nice and sharp and were ready to go. I suspect sharpening the fully serrated blade took about 10 minutes. I finished the sharpening process by swiping the blade on the steel. Here is what I tackled with the C36GSE:
· 1" I.D. PVC pipe - 5/32" thick: The thickest PVC pipe I have. Handled this task with aplomb. Made 10 cuts.
· 1 3/16" I.D. PVC pipe - 1/16" thick: Absolutely no match for the C36GSE. Went through this pipe as if cutting through paper. Made 1 cut.
· 1 7/32" I.D. cardboard tubing - 5/32" thick: A little tougher than sawing through the PVC pipe, but the serrations powered through.
· Garden hose - 5/8" I.D.: made numerous repeated cuts. Hardly slowed the edge down! This hose was one that was stiff from being exposed to the elements.
· Pruning - One of my favorite tasks to test out fully serrated knives. This knife is definitely a performer in this area. The belly of the blade accentuates the force applied to sever cleanly through branches up to 3/8" diameter.
· Plastic molding - 2 7/16" wide. The belly of the blade allowed the C36GSE to cleanly saw through the material. The cleanliness of the cut is comparable to that of a hacksaw. Made 2 cuts. The belly of the blade made it easy to slice across the flat section.
· Cardboard sheets - I did manage to cut A LOT of cardboard with this knife. The thickest sheets measuring ¼" thick. Boy, this was certainly no match for the C36. Went through the stuff like, well, a hot knife through butter! (A well-worn phrase but best describes the fully serrated 440V blade)
· Produce processing - The poor citrus fruits didn't have a prayer with the 440V! The serrations cut easily all the way through. All that was needed was a gentle sawing motion, and the knife just worked itself through. Cucumbers were the same way! CPM 440V could be the ticket to high-performance kitchen knives. Albeit expensive, I wonder how the price tag would affect sales? This could be something to look into if the company wants to venture more into the area of commercial food preparation (e.g. restaurants).
CONCLUSION
The Military C36GSE is a great combination of utility and defense knife, with more emphasis being on utility. The overall blade shape and size, along with the serrations, permit the knife to be an impromptu saw for light duty cutting jobs (as I had given specific examples above). Two brief recommendations: 1) The finger choil - add some notches here, like the early (circa 1996) models did. Makes for a more secure grip. 2) How about making a smaller Military model? Something like a 3" blade. Same features as the C36. Name it the "Cadet" or something similar.
[This message has been edited by Dexter Ewing (edited 10-02-98).]
C36GSE MILITARY
THE BLADE
THE HANDLE
PERFORMANCE
CONCLUSION
