Review of a Patton Bowie
In my quest to find light, fast, fixed-blade knives, I found Hossom Knives. Well, Jerry mentioned to me that he’d found another maker who had the same goals for knives, yet very different methods of construction. I finally got to meet this gentleman, Rob Patton, at the Blade show. Although getting to know Rob was great, my wife really topped a great weekend off by buying me a Patton knife for Father’s Day!
Well, I’ve been playing with it ever since I got back. My wife really could not have gotten me a better gift. Here’s my review:
Review
Blade: 9.5 inches
Handle: 5 inches, stabilized caribou and leather washers
Pommel & Guard: Brass
OAL: 14.5 inches
Weight: 13 oz
Blade Steel: 1080 high carbon
General aesthetic impressions: This knife immediately appealed to me because it has an "old fashioned" feel to it. Rob put an etch in the blade which really brings out the temper line, and the blade design itself is remarkable. When I first picked it up, I was amazed at how light and fast the whole setup felt. The point of balance was right at the guard, and the blade floats. The guard is wide, and comfortable, offering plenty of protection for the hand. The handle, as you're looking at it edge-down, subtly curves to the left. When I looked at the knife on the table, I thought that maybe my eyes were deceiving me. But, I picked it up and immediately understood why the handle was shaped the way it was. The wrist is put on a far more natural angle during cutting and thrusting moves, and I think that would promote both better accuracy and power. I'll have to keep playing with the knife to test this hypothesis, but my preliminary tests bear it out. I couldn't wait to play with it when I got home, so I went out and did a few tests over the past couple of days.
Picture of the Knife:
View
Close – Up of the Handle:
View
First: The "whack test". This is the test I use to see how resilient the knife is against lateral shock. I took the knife, and whacked the flat of it, HARD, repeatedly against a solid desk. The knife didn't care. It didn't bend, break, or complain.
Second: The "point test". The effort here isn't to break the point, but to see if it can withstand thrusts into semi-hard surfaces. I took the knife and stabbed it repeatedly into a pine board. Not only did the point thrust in well, but also it showed ZERO deformation, despite the fact that some of the thrusts were off-center. Due to the contours of the handle, it was very easy to hit dime-sized targets in the wood with straight, flat, and reverse thrusts. The point is still needle sharp.
Third: The "cuttin' dummy test". My cutting dummy is wrapped in carpet padding and duct tape. I sliced into that sucker with abandon. It bit clear through the tape and the padding, and bit into the wood. This knife cut better than knives even 2 – 4 inches longer. The only knives I own that cut better have blades 2 and 3 inches longer respectively.
Fourth: The "empty can" test. This is the test where I try to cut into an empty coke can with the knife. It took me about four cans to get the cuts right (I'm out of practice), but once I did I could cut almost halfway through an empty can (between 1/3 and 1/2 through). For a knife with a 9.5-inch blade, that's amazing. What was even more fun was doing a series of back cuts against the can. I could cut just as deep into the can with a back cut as I could with a forward cut! This knife performed better than just about any knife I own. Only two can match this feat.
Fifth: The "hanging paper" test. Snap-cutting hanging paper has never been my strong suit, so I’m going to skip that part of the review. I'm pretty sure that Gaucho could perform snap cuts into hanging paper with this blade, even if I can’t. So, realizing my limitation I went on to back cuts into hanging paper to see if that would work. Well, I quickly shredded the paper with a series of back cuts from each side. Keep in mind that the paper was hanging from a mere paper clip at the time.
Sixth: The "wearing the sheath test". This sheath is very utilitarian and straightforward stud sheath in the pouch configuration. I tried wearing the sheath around, and found that I couldn't do so and still draw the knife. Not a fault of the sheath, but in order to keep my pants up around my ample midsection, my belt is too tight to allow me to effectively draw the knife. So, I went upstairs and grabbed a gun belt, then tried it again. This time, it worked much better. There's more of a chance with sheath migration with the sheath held loosely in the gun belt, but it wouldn't fall out and I could get it out of the sheath much faster. What I’m probably going to do is make a back rig for this knife, in anticipation for the day when I move back to a state that allows for concealed-carry of blades. One thing to look at (if you can) is a sample of Rob’s wooden sheaths. Excellent.
Bottom line: For those interested in a workhorse utilitarian knife, this knife would work fine, but is not a heavy chopper. The edge was still hair leapin' sharp after these tests. For those who are interested in more martial application of blade work, they are going to be delighted if they get one of these knives. Be warned: As people in the American Bowie crowd start catching on to the quality of Rob's knives, they're going to be harder to come by. Word is already starting to get out, however, so get one while you can!
Rob Patton’s Web Page: Patton Knives
Waxes Eloquent, Leader of the Terrible Ironic Horde and Mighty Brain Spewer
Waxy's Custom Concealex Page
[This message has been edited by Waxes Eloquent (edited 06-17-2001).]
[This message has been edited by Waxes Eloquent (edited 06-27-2001).]
I need one.
The list just gets longer and longer
Mr. Patton's web site only 1/2 loaded for me, has this happened to anyone else?
Thanx for the great (as usual) review, good to 'see' you here!
Rob is a great guy. His training in Comtech/JAK's bowie methods is surely influencing his knifemaking to another level.
sing
AKTI #A000356
It has always been my pleasure to recommend Rob and his knives to any who will listen.
We share a common vision of what knives, especially fighting knives, should be, but follow entirely different paths to that goal.
The only thing we ever really argue about is the role of North Carolina in the Civil War. Rob's reading on that subject is limited to novels where the South won.
Well, we also argue about his website, but I happen to know that is being fixed by Atlanta Virtual as I type.
Great knifemaker, terrific guy, marginal Civil War scholar...
Jerry Hossom
www.hossom.com
The Tom & Jerry Show
Nice review, Matt
I had an opportunity to handle Matt's new bowie at the Blade Show, and I agree wholeheartedly with Matt's assessment of its feel and maneuverability. The handle is extremely ergonomic and the knife is perfectly balanced. It moves effortlessly. In fact, as I stood at Rob's table and picked up and swung one blade after another, I got that same warm feeling of inner peace and joy that I got at Jerry Hossom's table
. Rob's knifefighting training with Jim Keating is clearly showing in his work.
Mario
Gaucho
Tuvo muy mala suerte...se callo en mi cuchillo.
Did anyone mention that Rob is one heck of a nice guy?!!
I too enjoyed his knives at Blade, but his demonstration of the "harmonics" of his sword blades stands out in my mind!
Michael
It was also a pleasure to meet Rob Pattin.. even get the pre-bladeshow show of Patton KNives.. he is a very charismatic guy and I enjoyed meeting him (again).. I never thought I woudl like "this style" of knife but his temper lines, the "charming" look of his forged blades and not to mention his handles really present his knives in a great fashion
EM@IL: sniperboy01@hotmail.com
y8irl:and I want to be a destructive tool of [G]
URBAN.LEGENDS.(BalisongGARBAGE)
ENGEL.DESIGN.ROOM
will.design.web.pages.for.implements.of.doom
[FAKE01].[the mirror site](www.rejectionist.com)
Knives.I.Want
If you play with love you will be heartbroken; if you play with knives you will [bleed]
-S.Ching Theatre "Even prostitues are free to [dream]."
Had a good view of Rob's table from Blade Art's booth, and let me tell you, the look of ecstacy on all the Riddler's faces who handled Rob's Damascus Fighting Bowie was something to behold! Rob Patton understands how a Bowie's s'posed to move and makes a knife optimized for these specific techniques. I counted at least ten ROS veterans at Blade and all were drooling over Rob's work.
Great review Matt!
Mario,
Are you the one who scored the Damascus? Great knife!
Mike
Mike...I am that man
. My new Damascus Mandrita Bowie just arrived yesterday, in fact. My partners were absolutely blown away by its beauty and balance. I can't wait 'til this weekend so that I can really start to familiarize myself with it.
Between Rob's Mandrita and Jerry's new full-guarded Duelist, I do believe I scored the two best fighting knives at the Show. How lucky can one guy get?!
BTW, it was a real pleasure to finally meet you and Vince in person at the Show. I'm just sorry that we never found the time to play a little bit. Hopefully we'll meet up again at one of Jim's shindigs soon.
Peace and good training,
Mario
Gaucho
Rob seems to be having trouble getting his password sent from BF, so he asked me to thank everyone who has posted here about his knives. He's deeply appreciative.
I'm sure you're going to be hearing more of and from Rob. He is particularly anxious to respond to my comments on "The War of Northern Aggression".
Jerry Hossom
www.hossom.com
Hey Guys,...'bout time right?
Sorry for the untimliness here but so it goes. I'm still getting over the trip to Atlanta and to come back to stuff like this is blowing me away. Atlanta was the most positive show experience I've ever had and the enthusiasts/players and other makers that I met and hung out with were an outstanding group (from a group that stands out already...
) The kindness and support that I received there and here are what makes this knifemaking gig worthwhile. Thank you all.
So Matt, thanks for the review and I'm real glad you like your knife. Jerry, Thanks again for that fine southern hospitality. (BTW, I'm checking on seniors dicounts for the CW history lecture series at BSU this fall. I figure you can check it out when you come visit.
)C-4, the stogie was great and you should come to Orlando next month. Paul, always a pleasure. Mario, we'll be talking alot I'm sure I hope. Sing, I hope to see you in the canyon in Sept. Hiya Jonsey. Mike, I really appreciate your comments. And man am I touched, Tom I almost thought you had forgotten me, glad to see it ain't so, aloha dude. Steve22595, sorry I missed you but I'm sure we'll catch up in the near future.
I'm sure I left someone out but its early here on one cup of coffee. Thanks again and I hope to see or hear from you soon.
Best Regards.
Rob Patton
Tom,
The journey of a thousand miles begins with one step. Make that two posts.
Stats go up quick at this level don't they!
Aloha baby
Rob
Howdy all, don't post over here much (never, actually) but am making an exception here.
For those of you who haven't met Rob and want to know more about him, stop by Alliance and read our interview with him! http://alliancemartialarts.com/pattonknives.html
Also wanted to echo all the sentiments here - these are fine *fighting* Bowies made by a man who knows!
Best to all,
Pete Kautz
Yo Pete,
What a nice surprise, I'm glad you tuned in and I want to say a humble thank you for all your help and your support. Hope you continue to rock with Alliance and other endeavors. Two months to the Riddle!
Tom,
Touche man,....uh..isn't there an h in buddhist somewhere?
My best to you both,
Rob
