- Jul 23, 2007
Will it survive ? Will it break ?
OK I finally was able to do some hard stuff with one of my 420SS ones. Light twiggy things it seem to cut ok I guess, branch trimming, god my technique is off, plus didn't have a lanyard, I was living dangerously! Well I know an FFG is good at that so I went for hard use SP-51/53 grade stuff!
I batactitoned a tryranical log or two! The logs one so they got Mauled to death after an interruption to show them who was of the greater superior intellgenciealy!
OK reason they the logs won, they were wet seasoned naughty knotty pine types and the blade was an FFG so they were a no go. I smacked and wailed and went through a few baton sticks and left what left a small pile of saw dust. One was showing cracks but the wet wood was just holding itself having a very good swelly time. I smashed and bashed saber grinds throuigh these types logs before, a bit tough doing it but they were different critters better for such a job. So the fail was not the knifes fault but the user not using it for nice medium work, my medium is what most seem to call hard, and NOTE the fail was not getting the log split ONLY.
The knife blade...straight, no nicks or rolls and pretty still sharp. That's the real test I was tacti-testing out. Wet wood might not be much of a test, but the baton whamming I was doing all over the spine and one an off angle attempt, I think we can call this steel durable enough for steel vs wood jobs. To me the Woodsman is a multi-tool task knife that can chop pretty well besides being an ok slicer. But as shown in that U-tube review it can do what you would normally use it for.
My 5160 Woodsman had almost the same problems due to FFG blade, it wasn't the STEEL.
I tried a hatchet before using the maul, hatchet no go also.
So the Steel and Logs both one I say.
My I'll keep the 420SS Woodsman for my versions of light to medium duties for general stuff including kitchen. I''ll probably give one to some one who uses knives on farm things.
The baton was a poplar type, hence all the baton dust.
Editcus:
Well I'm one 420 SS Woodsman down, gave one to my little brother as seems the little sis wasn't around.
I told him it will make a good all round camp knife for woodsy stuff to other stuff, water tripping knife, and good chopper/cleaver/slicer kitchen knife, a usual literally ALL ROUND multi-tool and multi-task knife in one blade. The laminated scales should be water proof enough and to do like some one did with a file for more grippiness I saw some one do on the U-tube.![]()
OK...I'm getting yet another Woodsman, my 420 SS one is now full duty kitchen knife I use for about every thing in there. I'm not a fancy cook and don't believe in cooking 19 hours for a two bite dinner, but its heavy it slices and cuts things really good. Only the bread knife stuff it can't do very well. Yes its heavy, at times yes its clunky at some stuff but tenderizes things with its spine and other stuff kitcheny stuff okishly. I need a new one for woodsy camp knife food stuffy stuffy, or large critter cutting duties. My brother uses the one I gave him for kitchen mostly stuff as he has the other knives I gave him for out side stuff.
It could be my "Twiggy" technique for doing lighter stuff like that, but Woodsman did a better job at the twiggy stuff it seems.
I think the reason for the non tiredness working with the RTAC2 is the superior handle is my guess.
I’m still really reluctant to go for the 420 steel. Have you found that it is noticeably softer—it’s supposedly several rc points lower, and I’m worrried I would end up bending the knife if I used it to pry something, or lift a large rock, etc? I know 5160 will bend back, but I think the 420 would not.
Many people bash the 400 series of stainless because of bad experiences with cheap poorly heat treated knives. A proper ht on 420 or 440 will produce a quality blade.
Entrek knives makes some seriously tough blades all out of 440 stainless.
