Review of Valiant Survival Golok Small
Package, delivery & service:
There were some custom issues getting this Golok to Denmark. I don't want to bore you with them, but Wandi from Valiant was very helpful and he was very patient. At one point the post office was going to send the package back to Australia, but Wandi offered to refund my money if they did so or I could make a free order next time. That's what I call great service. Thanks for that Wandi. On the 26'th of April the package arrived in a well protected condition, I had to get past a layer of those foam bricks to get to the knife. The knife was protected with tape and one of those plastic sheets with bubbles. It was well taped, I had to use another knife to get it off, but also take care not to cut the sheath or handle.
Some quick facts:
5160 steel, also called spring or truck steel.
Full convex grind.
33 cm blade (13 inch).
6 mm thick blade at base, but tapers towards the tip.
Water buffalo horn handle with beautiful carved marks and a big heavy pommel.
Fingergrooved handle, they are nice and doesn't irritate.
The tang is inserted red hot to the horn. And no, it's not a full tang. This is better than a full tang as vibration isn't felt through the handle.
Wooden sheath with horn
There's approx. 10 hours of work in one knife.
First impressions:
When I got the knife out of the protecting layers and grabbed the handle I felt: Wow. This is a nice handle. I pulled the knife out and out came a very beautiful blade. It was mirror polished and had a protection coating on it, some sort of oil to prevent rust during transport. This, I consider excellent service.
It's a heavy blade, around 500 grams, certainly feels like a lot more. It is well balanced and feels like a real chopper. So I tried the edge with my finger and it didn't really feel THAT sharp, but boy it was, (I was to discover that later on
One of my first impressions was also that it's a very beautiful blade, handle and sheath. I find it surreal to be able to make a knife like this for 65 AUS $. There's 10 hours of work in one knife and all is handmade without the use of powertools. The people who makes them doesn't even begin to know how beautiful blades they make.
Quality of fit and finish:
The finish is good on the handle. It is completely smooth and it is generally well made. The blade is inserted straight in the handle, but reaching the tip it is bended just a little. But it is not noticeable at all when chopping. As a matter of fact the only way you can see this minor error is by looking down the blade. The grind could be a little smoother; it's divided into three sections if so to say. This has no effect on the chopping and is barely noticeable without looking carefully at the edge. The sheath is wellmade, not that secure or durable, but it protects the knife and it protects you, and that are the two main jobs of a sheath in my opinion. It has horn on it and is not that straight everywhere, but there's a lot of detailwork. It has a rather small belt device to hang it from a belt. It's also made of horn and is secured with two small nails. The hole for a belt is small though: 3 cm. maximum. I can hold the knife upside down while it's in the sheath and it will stay in there. But once I start shaking a little, it will eventually fall out sooner or later. This is not a bad thing; it makes the knife easy to pull out.
In use:
This is a really really good chopper. It's the most effective thing I've ever seen. Compared to a Cold steel with the same blade length, the Valiant wins by miles. And it's cheaper and more beautiful too. I've done all tests with factory edge and right from the box. I could chop through a 5 cm thick branch with one single chop. Furthermore I chopped down a smaller tree approx. 8 cm thick, in about 6-8 chops. Sometimes the golok was stuck, but it was fairly easy to get it free again. Even after a few hours of chopping and cutting, my hand didn't have one blister, just a little hard skin. The handle is very comfortable and feels good in the hand. It feels like the tang is inserted solid to the handle and is going to stand up for many years of service, from this day. No vibration is felt through the handle, because the way the tang is made. If this knife were full tang one would feel a lot more vibration than now. And yes I'm sure this kind of tang (red hot inserted) is solid, just as solid as any other tang. I believe the convex edge adds to the overall effectiveness, cause it just slips through the wood at impact, if you know what I mean. I'm just starting to learn the draw cut and am getting the hang of it. Jean-Marc advised me to hold the handle lower than the tip. I tried this and boy does it work Very effective cut as the knife both cuts and slices through the wood.
Conclusion:
I love this knife. It's a beauty to the eye, yet a super bushcraft knife. Most important task for this fellow is chopping and one has to see it to believe it. And it's very cheap. 65 AUS $ for this one and of course insurance and shipping costs is added to that later.
Below you can see some images of the golok in use and some different views of it. If there's anything you'd like me to deepen or an angle of the knife you'd like me to shoot a pic of, let me know.
Cheers.
Some quick facts:
Full convex grind.
First impressions:
In use:
Conclusion:
Cheers.
