- Jun 8, 2005
I'm very tired and busy this part of the week, but I wanted to take a break and write this review...I'll expand on it when I get more time around thursday probably.
The first thing that strikes you about the para is it's size. It has a very reasonable three inch blade, but compared to other folders of similar blade length, it really appears something like 75% bigger. The handle is enormous and the blade is beefy. I got the para mostly for the handle. I wanted a three inch blade for EDC, but my minigrip and m16/11k handle's were just a little too short for my pinky with my reasonably large hands (but definitely not unusually large hands). The handle is a full inch longer than the M16/11K's, maybe as much as two full inches if you count the top finger choil. Because I can fit my entire hand easily on the handle, it's very comfortable, and the G10 is very well textured and grippy. Also, I find I have two comfortable ways to hold the knife, with my full hand on the handle, or choke up to the choil on the blade for more precise cutting. The only ergonomics complaint I have is the little bump/curve half way through the handle, which raises some of my fingers unecessarily. It's not uncomfortable so much as strange feeling.
The action on the knife is fantastic, second only two an axis lock or axis lock ripoff....or flipper knife. The extra large spyder hole is very comfortable to open, but the very heavy blade makes it very wrist-flickable. If you hold down the compression lock, it's flickable open and closed, just like an axis lock with a little more effort.
The lockup is very good, and if I'm to believe the hype, extremely strong. I didn't feel like testing it tonight, but I might next week. I like it much better than a liner lock, not for the allegedly superior strength and reliability, but because it's easier to get to and doesn't put you in the path of the blade.
it seems like everytime I review knife, or almost everytime, I have to say something like "this is the sharpest knife I've ever used." By some coincidence, almost every new knife cuts better than the last, perhaps due to the increased funding. The paramilitary puts all my other knives to shame, however. This is the first knife I've owned that, out of the box, doesn't just cut the arm hair, it's like a razor blade, the hairs just popping off on contact with the edge and becoming a neat little pile in front of the blade. I will test it against cardboard soon. The blade is extremely beefy, its spine is about 2.5 times wider than my M16's. This is a very tough knife indeed. I have a lot of confidence in it. S30V, of course.
Fit and finish is excellent across the board, with the minor exception of the surface on the rear most spine of the blade, the notches for your thumb to grip. They're extremely grippy, but appear uneven and rough. This might be intentional, but it's not very attractive. I don't much care. Also, the blade is less than a mm off to the side at the tip when closed. That's sort of annoying, but not a big deal.
The clip grips well and is nice and long, but this knife is much larger than comparable 3 inch blades and most of it will extend from your pocket. This is a necessary compromise if you prefer longer handles, like I do.
Not a bad offering for just over a 100 USD.
Look for a three way EDC comparison between the M16/11k, D2 Minigrip and Paramilly coming soon. Three very different takes (and prices) on what an EDC should be.
