- Mar 17, 2010
just got my road id "wrist id elite" yesterday. it's basically a modified dog tag to wear on your wrist. you get 6 lines and 24 characters per line to customize...on the 2nd line i have nka (no known allergies), nkda (no known drug allergies), and no med hist (no medical history).
i've been hiking and mountain biking for awhile and never really felt the need to carry something like this until i bought my 1st road bike a little over a month ago and since then i've had a few close calls already...a quick check of any roadie forums and you'll easily see people are a-holes and will leave you bleeding on the side of the road...figured i'd post a review here for those looking for extra peace of mind but never heard about this product before.
size comparison...i usually wear my watch on my right, it's just there for this pic though.
this particular version comes in a tin can.
back view. the whole thing is around 10" long and the strap's underside has grooves evenly spaced so you can easily cut it to size and keep it straight.
it has a watch-like locking clasp. the whole thing is actually pretty low-key/classy - it won't stick out if i wanted to wear it while wearing a suit, for example. the nylon version of it looks too sporty though especially with the reflective stitching and all that.
all the metal hardware is brushed stainless steel. the band and the metal id are available separately (if info changes or you just want a different colored band).
the tin can by the way is about twice as thick and 50% wider than an altoids tin.
closer look at the tooty clamp...after you trim the rubber to length this thing really bites down on the strap and locks in place. i had to trim some more so i had to use a flat head screwdriver to re-open it...it's not going to come loose in normal movement and fall off for sure.
the instructions.
i like it so much i think i'll order another one for $%*Ts and giggles while bar hopping with my buddies. this one will say "if found with slurred speech but otherwise conscious, i prefer maker's mark...no ice please!"
the instructions.
