REVIEW: RoseCraft Blades Overall Creek Farm Hand Yellow Sandalwood RCT022-YSW
BrotherJim
Just arrived into my hands Monday afternoon and going through the bonding phase. Totally impressed with this Soddy iteration. I don't usually do much of a review of a new knife but here's an exception.
The RoseCraft Blades Overall Creek Farm Hand Yellow Sandalwood features a 2.9″ D2 drop point blade with a brushed satin finish. It’s 2.7mm thick and has a half stop. This one-bladed traditional slip joint is the first RoseCraft traditional to be bolster free. It has steel liners, nickel silver pins and a birds eye pivot. The covers are genuine Yellow Sandalwood with diamond checkered grip. It’s 4″ closed, 6.9″ overall, and weighs 2.5oz. Based on traditional farm and ranch patterns re-imagined by Andy Armstrong.
That blade design is something I've never seen on a Soddy before and it appeals to me. Oh yeah ...
Asked and Answered: Andy Armstrong answers popular questions about RoseCraft Blades November 2023
One of Andy's design features I noticed, that is much different than something I've seen on a half-stop knife before. Every other half-stop knife I've seen, has a flat area of the tang that engages the spring at the half-stop. Well, the picture isn't the best and the little paintbrush line I drew doesn't represent the tang half-stop area perfectly but as you may be able to see, instead of a flat area of the tang, the half-stop area has two "humps" that contact and balance on the spring when in the half-stop position. Incredibly there is absolutely no blade rock at the half-stop. NOTICE TOO: The spring is absolutely flush with the blade closed.
And the other end of the knife, featuring blade centering ...
Spring is also absolutely flush at the half-stop ...
Not only that, the spring is absolutely flush when the blade is open and the spring to tang transition is quite smooth ...
Blade bevel is very even ...
Even more blade bevel ...
Blade well ...
Nary a gap anywhere around the spring and liners ...
This thing is a production knife folks. Production. Andy Armstrong and his team of designers come up with RoseCraft knives and then have them made in China. Obviously there are some pretty good and consistent worker bees out on the knife farms there in China. Dang. No where on the knife does it say "China", only on the box. Some RoseCraft knives come with a little oval sticker on the pile side of the blade that says "China, but this one didn't even come with that. Andy Armstrong says he will only use removable "China" stickers if on the knife. Never will he stamp or etch "China" on the knife ... so far anyway.
There was a little shop grit in the works but was easily cleaned. Action is smooth. Not ball bearing smooth but smooth. Blade pull is about a 5. About what you'd expect with a Case Soddy ... or Maserin Plow. All pins are flush with the covers. No hot spots on this knife and the Sandalwood checkering gives a hint of grip assist but isn't intrusive. Walk 'n Talk has a "thunk" to it.
There is no blade play whatsoever anywhere and I tried to find some. Additionally, while the tolerances are tight, I could not find any tang marks indicating liner rub when opening and closing and I looked. MAYBE a very slight touch of the tang to the liners because when opening and closing the tang does pull a thin film of lubricant but I don't see typical lines, marks on the tang of metal to metal interference. Not yet anyway.
First impression: This one is a winner if into Soddy type knives 🏆
Thanks Mitch :cool:
Of course with any production knife, this is an element of luck of the draw and maybe I just hit the jackpot with this one.
But I viewed equally impressive reviews on YouTube before pulling the trigger and am inclined to think QC and quality production is pretty consistent on these.
The first picture in the OP shows the mark side of the tang but I forgot to show the pile side.
On the pile side is an Andy Armstrong "A", under skull and crossbones ... D2 steel and the knife model number.
The tag on the end of the box is the only indication of "China".
Different lighting for this picture than the first OP picture, so a little different Sandalwood look I guess, but the covers do match, even as far as the checkering orientation points.
Compare the points and position of the checkering in the first OP pic with this pic ... Mark/Pile. It's uncanny how they are in the exact same position on both sides.
On the butt of the handle, you might be able to see the only "flaw" I've found with this knife. It's where the scales come up to a "point" at the butt.
The scale on the pile side is ever so slightly more rounded than the top of the scale on the mark side. Not a show stopper 🤣
Very thorough & articulate review thanks Jim, this is what objective knife discussion is all about: evaluating the knife or as Levine used to exhort "Read the knife"
I very much like the look of this pattern but have not yet had the chance to get one. Appears very well-finished, thought out yet up to field work. I have their Stag Gunstock and have been impressed with both quality & performance, the D2 came really sharp with good grinds.
Thanks, Will
I own several Rosecrafts and am pleased with all of them, and one of my favorites being the Loosahatchie Jack in sandalwood scales. What a great job they do on that wood finish. I just have so many knives in D2 nowadays. I do wish Rosecraft offered more carbon options.
Thanks Will !!!
I have a RoseCraft Stag Senator that should be here Wednesday.
The stock pictures looked great ... and then I was offered the choice out of three on hand.
I'd asked for pictures because stag can be tricky ya know.
None of the three look as good as the stock picture ... but I chose the top one (top in each picture) ...
I think the bottom one looks okay too.
I like the shape of the middle one but it looks smoother than the other two.
- yes, something to shout about........think this (sodbuster style as OP) is one of their very finest knives.
It has balance and proportion all very nicely done.
The walk n talk and finish on mine is excellent, and when comparing with cost - awesome.
Know many of you guys love your carbon blades and patina, but for me, this in a decent stainless would be 😍
Great coloring right there!!! 😻
John :)
Awesome review, Brother. I have quite a few Rosecraft knives and I have zero complaints about any of them. Even have a couple from their 'Seconds' sale and I have been unable to find anything wrong with those. I'll never hesitate to buy Rosecraft with how the quality of their knives stands right now. Andy does a great job with his designs as well. Glad to see a little Rosecraft chatter too, they deserve it. 👍
The checkered handles are awesome, they definitely make nice knives. I'd prefer thinner blades but that's just a personal choice, by all objective measures they're great value. I have a sowbelly and a loom fixer, both are awesome, the sodbuster was definitely next on my list
