Well, I bought a new hawksbill to replace that damn Smith & Wesson Cuttin' Horse. Here's the Byrd Crossbill, model number BY07. It's a plain edge; no serrations, and can be had in stores for about $20. Here's the rest...
Handle Specifications and Impressions: The Crossbill's handle is solid stainless steel, and is 4.9" long. The knife, not including the pocket clip, is .25" wide. The skeletonized stainless pocket clip is made for tip up or tip down carry, but the handle is drilled for right hand only. It's held in place with three Torx (T-6 screws). There is a lanyard hole in the butt of the handle, and there are three diamond-shaped holes at the lower portion of the handle. The knife locks open via traditional lockback, positioned in the middle of the handle spine. There's a Boye dent so that you don't close the knife by gripping it tightly. Two finger grooves help in controlling the knife. There are no markings at all on the handle or the pocket clip. I will say that this handle is slippery when your hands are wet or sweaty. The all-stainless handle is great for weight, but bad for grip. If they'd make a G-10 version, it would be really good.
Blade Specifications and Impressions: The Crossbill's blade is, of course, a hawksbill shape. It curves inward, like a talon. It's 3.5" long with a 3.1" cutting edge, and is .145" wide. The blade is hollow ground and made of 8Cr13MoV. Rockwell hardness of mine tested 58 on the machine at work. The left side is marked "byrd" above "8Cr13MoV" on the tang. The right side has the circled TM near the thumb hole, and "CHINA" near the tang. The blade opens via comet-shaped thumb hole, which is 1" long by .5" wide at its widest. The blade also has an unsharpened swedge on the back, which measures 2.25" long. The point on the blade isn't flimsy, nor does it seem likely to break. The "sweet spot", if you will, is about an inch from the blade tip. This is where all of the material seems to end up before it meets its demise from the hooked tip. The entire blade came shaving sharp right out of the box.
My only complaint about this knife is the slippery handle. If a G-10 or FRN version were available, I could see a lot more being sold. Since this is being marketed as a knife for mariners or fisherman, you'd think more thought were put into a non-slippery handle. Otherwise, this is a great knife that will be in my pocket... albeit with a lanyard attached for grip when pulling it from my pocket.
