Review: Three Sisters Forge Tactical folder
Link: http://threesistersforge.com/
Alright guys this is a review on my first custom made folder, the TSF(Three Sisters Forge) Tactical with IKBS Bearings. Jim of Three Sisters Forge is an awesome guy to work with. Many of his folders are out in action with our Soldiers and out on the streets with our LEO's. Jim makes these folders with them in mind. I have only carried it for a few days so i will share as much of my own experiences with this knife as i can. Here are some quick specs:
- 3" blade of CVPM S35VN steel. 59 rockwell, triple-tempered and -300 cryo-quenched. Hollow ground with swedge and .185 thick. Bead blasted then Stone washed.
- 7" overall
- .120 thick Titanium scales with water jet texturing.
- IKBS opening system.
- Flow through back for easy cleaning.
- Depending on materials used, MSRP is between $200 and $300. Discount for Military and LEO's.
Blade:
The blade shape is great for edc and hard use. The hollow grind makes it an awesome slicer and the swedge reinforces the tip with a lot of steel behind it to make it durable when penetrating tough materials. This blade performs well in the kitchen. I already sliced up a banana and some carrots with no problem. The knife also slices nice and smooth through card board. I took down around 8 flat rate priority boxes that have been sitting in my garage for some time with little effort. I was pleasantly surprised the edge was still hair poppin sharp. This is the first knife I have owned that uses CVPM S35VN steel. As far as I can tell the edge retention is superb.
The bead blasted then stone washed finish on the blade is well done. I myself prefer a just stone washed finished which really helps in hiding wear, however this finish is very smooth and really helps reduce the friction and drag between the blade and any material the blade is slicing through. Like I said before, this blade takes little effort to slice through materials. The thickness of the blade allows it to be an effective slicer and at the same time is stout enough for more heavy duty chores.
Scales:
Both scales are made of titanium. The framelock side has a smooth bead blasted then stone washed finish. The non-locking side has a beautiful grip pattern that is engraved by a water jet. The grip feels really nice to the touch. Its grippy without being to sharp or catchy. When putting the knife into my pocket it goes in nicely without catching onto the material.
IKBS Bearings/Lock Up:
This knife is the first one I've had with the IKBS bearing opening system. Before this knife I've never even heard of this opening system. I really do not know much about it except that it is the smoothest opening system I have ever handled hands down. Instead of using washers around the pivot the TSF Tactical uses ball bearings. Its so smooth I dont even know how to explain it. I guess its like if you had a glass top table, put some marbles on it, then put another piece of glass on top of those marbles and rolled it around lol. Its smoother than butter.
Lock up is around 50-60% and is like a bank vault. No blade play whatsoever. The lock bar sometimes does get stuck when the blade is flicked opened. I suspect it will eventually break in and stop sticking. Its not a big concern to me.
Thumb Stud:
What I really like about the thumb stud is it sticks out past the Ti scale a little bit. This allows your thumb to get a really nice purchase on it when flicking it open even if you are wearing gloves like most LEO's, EMS, and Military personnel do.
Pocket Clip:
The pocket clip is heavy duty and carries nice and deep in the pocket. The extra long clip makes sure that this knife will stay in your pocket. Another really nice feature is the space between the clip and scale. It allows for the knife to be clipped to thicker materials and I've even clipped it inside the waist of my jeans and it slipped in nicely.
Tolerances/Fit and Finish:
The tolerances are nice and tight. Everything fits perfectly. The blade is dead centered.
Fit and finish is good. However if you are looking for perfection like the Sebenza then look else where. The knife doesnt have imperfections, but it does have markings which lets you know the TSF Tactical is a hard use folder made by one man in his shop. I like it… these marking let me know this knife is mine and there is no other like it.
Closing:
I would say the TSF Tactical is like a Sebenza on steroids and cost less. I mean a custom folder made with the best materials out there and cost less than a production made Sebenza? Thats a deal. And I love sebbies. The TSF Tactical is a great folder for edc and hard use. If these blades are good enough to be used in battle by our Soldiers and LEO's then I think the TSF Tactical can take anything thrown at it here at home.
Thanks for the review, I was checking these out the other day and really liked the look of them. Personally I would like an XL version though. 7" OAL is a little on the small side. Otherwise it looks fantastic. And yeah, a stonewashed blade would be the heat!
Thank you for a very kind review.
METALS: There has been big deals about blade steels forever. My personal opinion is that it is much adoo about nuttin. Last year I made knives out of 440C, 154 CPM, S30&S35, 1095, D2 steel. All six were identical, bead blasted rough to hide color differences. I has attending a hammer in with some of the biggest names. Except for the 1095, due to edge exposure, no one could tell the difference. There was VERY little difference in cutting and edge holding.
Difference ?? The real difference is in the heat treat. The rest is BS.
When looking at a knife ask for the heat treat pedigree.
Still love 1095 and damascus, you can read the heat treat on the steel.
Very nice -- thanks for the review.
What is the weight of the TSF?
Would someone be kind enough to post photos of the TSF with a Sebenza for reference?
Nice review, I like the look of that knife a lot and it's the perfect size. Does three Sistres make that folder in 1095? That would be awesome!
Here is a quick one of 2 of my favorite EDC's...sorry for the glare on the TSF's edge, has a nice Edge Pro polish on it :)
It would depend on heat treat, but everything except 440C and 1095 should have similar levels of wear resistance. I'm also curious to know what a "hammer in" entails. All I know is, there's a definite difference in edge holding when I trim corn with S30V and CPM-M4(spyderco heat treat).
Still, not like it matters. S35VN is stainless and 20% tougher than S30V. Seems to be the obvious choice for a hard use folder that you can drag through the mud, and leave the mud on the blade as well without fussing over rust:thumbup:.
It's also a tradeoff over giving up toughness/corrosion resistance for more wear resistance. Having S90V in a small lightweight folder like the Para2 in Carbon Fiber best compliments the steel's traits in order to ensure nobody is stupid enough to try and stab the small knife through a car door. Having S35VN in a hard use folder also compliments the knife's design and intended use.
I'm really liking the black finish, I have one coming my way in a "lefty"
Jim is "top shelf" and his knives are the same, you can't say no to him!
I just got one of these 2 days ago, your review is pretty dead on. Only thing you left out though, the handle shape is amazing in the way it locks the knife into your hand. Unless you have XL meat hands the TSF is locked with a full 4 finger grip. Might be on the trading block soon though, I am a college student and want to try many brands before I settle down with one :)
I have one of the TSF BEAST folders. It is an awesome daily carry knife. The heat treat is great and the knife gets very sharp and has great edge retention. If you ever need help, before or after the sale, the customer service that Jim provides is outstanding.
Hi,
I can testify that Jim makes some of the best custom hard use folders out there. For custom knives, His prices are very reasonable, He is a great Guy to work with because He listens to You. He goes above and beyond to deliver a knife that works excellent. Just fitting the knife He breaks down the knife @ least 10 to 15 times, to make sure that things are right. He also holds break in parties with His friends so each blade has been opened a minimum of 100 times, so it is somewhat broken in. He couldn't possibly charge for all the time that He has into the knife, because it would be cost prohibitive. He does these things, because He is a true Craftsman, who cares about the product that He delivers!
I purchaced the Beast and a CCT from Him, which are both EDC'S. He surpassed My expectations, as I'm sure He will Yours!!! You will not be sorry if You buy from Him.
NOTE; My Avatar is His CCT
Thank You for letting Me add My 2 cents worth!
Charlie
Could someone else post a picture with a small sebenza. The one above has been deleted.
I will be ordering the "beast" within the next 3 weeks can't wait. Looks to be my perfect/Grail knife.
I like the looks of this one it looks to be the perfect knife for me I mean s35vn and IKBS thats something to drool over.
