I have completed the first leg of my education in sharpening by reading and using the practices found in "The Razor Edge Book of Sharpening" written by John Juranitch. The Book is very informative but I found that what they piled on to 143 pages could have been said in about 35. Anyway this is a post to put up what you think of shaprening. I am going to put up a couple of thoughts and you guys fire away with whatever you have to say.
1. The fact stated in the book is that for finishing your edge with a fine hone there is no magic angle. It states as long as you keep your angle under 25 degrees you'll produce an excellent edge. what do you think?
2. It states that you only need a coarse and ultra fine hone ( which they just happen to produce the supposed best two) to get the perfect edge. what about medium hones for preparing the edge for finishing? Needless step or a good idea? Who do you guys think make the best hones? Share web sites if you got them. it could help us all to have more resources between us.
3. It states that most steels (for steeling your blade) are junk because they are too rough. they say that a steel is worthless unless you can see your reflection in it? Is steeling needed or perhaps just finishing your edge on a rock hard 1,200 grit stone? Are those two options basically the same thing?
4. It also states that Most to all manufacturers put an aweful relief on their blades and to get a pefect edge you have to grind away half of the blades face to run the secondary bevel almost into the edge itself. Now this would void most warranties on knives and would make them as ugly as sin. Is this craziness or worth while for the ultimate edge?
5. What are sharpening guides good for? Do you guys think they are needed or just a crutch for the novice?
Remember... I am not giving any opinions here jsut topics of discussion so if you see something that goes against everything you believe to be true, don't cuss me out. Just wanting to discuss this with my fellow blade lovers. Any advise from the expert or the experienced dabler is greatly appreciated.
Everything is negotiable!
http://albums.photopoint.com/j/albumList?u=879893&Auth=false
