I have a bad history with debates on wool vs. synthetics, so that's not what I'm trying to start again. Just want to clarify a few points that might be helpful. But lets keep in mind that this is a very specific set of methods where fire is not possible, and shows the capabilities of modern materials. I don't think its the end-all-be-all of systems, but I think shows what having the right gear can do. I also think its a better option in most cases than "I'll just light a fire" that won't always work, seems this would have a better chance. Its my opinion, having suffered from hypothermia several times, slow and fast onsets, that the only fire that is going to be useful is one that is already set. A waterproof firekit is not enough, it needs to be a fire, ready to go, with as little help as possible. That is a tall order. In my mind, thats the only fire that counts.
A lot of the hypothermia stuff that gets tossed around is based on really poorly done trials in the 40s, by the kind of people who thought you could "train" out of dehydration. We do have a lot of better info now, and we know a lot more about how the body reacts and starts to shut down.
First aid for hypothermia is "cold fast, warm fast, cold slow, warm slow" worrying about limbs and such only matters for frostbite, and that's a different problem with different concerns. The cold blood thing is a myth. What can happen is that in cases of extreme long exposure hypothermia, in a case where there is severe frostbite, the person can have what is in essence compartment syndrome. The blood that is in the limbs can be toxic to the heart as it contains the breakdown products from the dying tissue. There can be complications from warming up someone too fast, but that is different, has nothing to do with the limbs. The body needs to be able to compensate, and just like heatstroke, as it gets farther from ideal temp, the harder it is for other systems to cope. But if the person has been submerged, so they have lost a lot of heat over a very short period of time, they should be warmed up as quickly as possible, in conditions comfortable to another person. They have no concept of comfort temp, so its easy to over-compensate and over heat them, but there is no real need to warm someone really slowly in that case.
Wool is better than cotton for being wet, this we all know. But modern synthetic materials can drain water out far faster, so for the specific purposes of the re-warming drill, wool would not be a good option. Keep in mind, the layers they are describing are a moving layer, and a sentry layer, most people don't do that. The re-warming drill is also not simulating hypothermia. Its simulating a soaking event, and the goal is to dry everything out before hypothermia sets in. Wool is going to take longer to dry out, for the insulation value, is far heavier. Sure it has its place, but none of these materials are magic. Use the appropriate material for the situation at hand.
I also want to say again, lets not make this a materials debate, stick to the merits of the rewarming drill. I just wanted to clarify a few things about hypothermia that I see passed around very often as truth, which is very old info.
