Wowbagger
- Sep 20, 2015
PS: I realize this belongs in maintenance; just wanted to leave a flag here in General before it gets moved.
thank you mods.
Turns out with the right tools this stuff was crazy easy to reprofile.
I'm still pinching my self !
No pics ( but it happened ). Maybe pics later / tech wise I'm very limited right now.
Come on, you can imagine a big wide polished edge on a Sage.
Equip. =
Old Edge Pro Apex
Lots of spare blank aluminum plates like for putting polishing film on
First plate / grit was a section of a sanding belt (cut it well short of the ends of the plate, don't ask why just be glad you didn't have my F'up). Cut to length by folding belt in two and ripping ( =super easy). Norton BlueFire Zirconia Alumina 1inch wide 60 grit. Held to plate with side by side strips of 1/2" double back tape.
All the other stuff I put on the other blank plates was ditto.
Atoma 140 for E.P.A.
Venev Diamond plate C 100% F60 250/200 for E.P.A.
DMT plate for the Aligner, (has the round holes in the steel plate) Blue 325 mesh 45 micron, stuck on E.P.A blank.
DMT plate for the Aligner, (has the round holes in the steel plate) Red 600 mesh 25 micron, stuck on E.P.A blank
DMT plate for the Aligner, (has the round holes in the steel plate) Green 1200 mesh 9 micron, stuck on E.P.A blank
******WARNING ! WARNING ! WARNING ! ******** wrap or tie thick rubber bands on sliding rod for stops so you don't have these short aligner stones flail off the edge of your knife; or better yet use longer / proper stones for the guided sharpener you are using. I'm just saying what I patched together.
Edge Pro Diamond 4000 "Diamond Matrix" stone . Seems to be grit in resin; off white color. This stone is scarry to use because it seems to be only for trailing edge (stropping like motion). Going edge leading seemed like the edge would just cut into the resin matrix.
At this point I was somewhat tree topping sharp but with a super small bur edge.
I attenpted to take off the bur using a solid steel plate with metal bonded diamond going edge leading . . . the stone is a P.D.T. , Premium CBN, 15,000 grit No912 for Edge Pro.
The edge bevels got prettier but the bur remained. I then went both directions (leading and trailing) to abraid the bur off. Still hung on.
I increased the sharpening angle; twice !!!!!
Still there !
I banged my head on the wall. That didn't help either.
I finally resorted to using a rather tired and cut up cow hide strop, I had pre mounted on one of the aluminum blanks, finished side, that long ago I loaded with 50,000 diamond paste.
That pretty much did it.
It's crazy sharp and pretty. I'm not happy with it because of those half assed final steps but . . .
if it had been M4 my Norton 8000 water stone would have taken care of that bur, hell there probably wouldn't even have been a bur with M4.
My hand kept reaching for that little magic yellow Norton 8000 but my brain kept telling me how stupid that would be for REX121.
The edge was fantastico off the Green 1200 Aligner stone, I don't recall a bur at that point and the bevels were getting pretty shinny.
The main thing is she's thin, layed back and SHARP ! (all that's an understatement)
Now we will see how long super thin will hold up.
Was I a wimp; should I have gone for .006" behind the hedge ? .004" ?
Hey, I'm not Shawn Houston or Phil Wilson , OK ! ? !
edits for spelling.
thank you mods.
Equip. =
Old Edge Pro Apex
Still there !
edits for spelling.
