- Jan 12, 2016
Thanks. Totally forgot about them. The new ones are not in stock though.What about lynch? I can confirm that the retention is jacked up from the stock clip without being a pocket killer like the Impinda clip is.
What I do with the stock clips is take them off. Put them in a vise padded with wood, rubber, plastic. Whatever won’t damage the sand blast texture. Then pull towards me a bit to bend it slightly. When you install you should have to push the clip down slightly to get the screw in. It holds on every thickness and type of material I’ve tried it on. I did it to my new large 31 a few hours after I got it.Hi all,
I have a Large Inkosi and want something that won't slid out of the pocket so easily. I can't seem to find a Millit clip. What about the RGT 3D milled clips, or the MXG milled clips? They good? Thanks.
Ah I didn’t know he had a new one. I have the rounded one and that’s in stock. I think I like the way the original looks better, but maybe the new one is better in the hand?Thanks. Totally forgot about them. The new ones are not in stock though.
My question is, out of all the aftermarket clips which ones fit the milled out pocket for the stock clip the best?
that looks awesome. I will say that I find the lynch to be jarring on a 31 or inkosi that has an inlay. The inlay is framed around the stock clip, so you end up with a big gap with the lynch.Absolutley love my LyncNW clip. Its got much much more rention than a factory clip but the wider surface doesn't murder my jeans.
Guessing you blasted that at the same time as the knife? Looks excellent.Absolutley love my LyncNW clip. Its got much much more rention than a factory clip but the wider surface doesn't murder my jeans.
Does it wiggle at all under side torque?I’m really liking the MXG clip. The retention is just perfect and notably better than anything else I’ve tried. I normally opt for RGT but tried this last MXG on a whim and I love it. The shipping was really fast too.
Side note: DLT Trading just got a huge shipment of CRK clips in if that’s your thing.
Would you look at that! It does, ever so slightly. When I was installing it I thought the surface area looked a little small in comparison.Does it wiggle at all under side torque?
I live in that same world!Would you look at that! It does, ever so slightly. When I was installing it I thought the surface area looked a little small in comparison.
This is going to drive me crazy.. now I’ve gotta replace it![]()
Yes sir.Guessing you blasted that at the same time as the knife? Looks excellent.
Yup. That’s why I haven’t bought any aftermarket ones yet. Does the lynch? Millit?Would you look at that! It does, ever so slightly. When I was installing it I thought the surface area looked a little small in comparison.
I’ll have to check later. RGT does not move at all.Yup. That’s why I haven’t bought any aftermarket ones yet. Does the lynch? Millit?
Lynch is a fully keyed feature, much like the OEM clip... But machined from a single piece.Lynch doesn’t budge. Quality product I have on 4 small sebenzas and 2 large. Also on my umnumzan. I highly recommend
Disappointed I missed the new Lynch clips. They look really good.Lynch is a fully keyed feature, much like the OEM clip... But machined from a single piece.
