- Apr 4, 2023
I'm always trying to learn, amateur sharpener for sure. What I've learned has been from YouTube vids from guys who ain't always right, some are.
I said all that because I often get a work knife from a person and I try new things I've watched or I may just want to prove/try something for myself. Last night was one of those nights.
I'm using a TSPROF Blitz 360, sharpening a Manix 2 @ 14.5 dps and decided instead of just doing my thing for each side of the blade I would count the passes I made from heel to tip and back. To be specific, start sweeping at the heel, go to tip and back to heel, this is 1 pass. Then again, #2, and again, #3................ until I get my burr, then flip it and repeat. Now keep in mind I'm reprofiling this knife, using Venev Diamond Stone 80 grit as my first stone. I'm not trying to prove the same amount of passes on one side is what you do on the other. I'm only trying to see where I'm at.
So I make 41 passes on side 1, got a burr and flip to the other side. I just wanted to see after 41 passes on side 2 how close I was to achieving my burr, this was my purpose, I'm experimenting. I'm not trying to prove anything, I just wanted to see where I was at when 41 passes were made, that's it.
Now on side 2, after those passes I see I do have a burr but I also see my bevel is much wider on side 1 (see pics below). Got drug away by the wife and never got back to the knife.
Tell me a couple things.
When I go back to the knife tonight, do I keep removing metal on side 2 until my bevel becomes even with side 1 ? I believe the correct answer is yes.
***Now Letoff, why are you asking this ? *** Cause freakin Youtube ! There's a guy, I'm not going to tell you who, but he's got a following, I'm one of those followers. I was flipping through youtube this morning and I see a vid by him, it's exactly what I'm asking you. HE SAID NO, I would continue removing from Side 1. He presents this very thing where the bevel is wider on one side than the other and says you keep removing from the wider side, he doesn't demonstrate it, he's just presenting the situation and giving a solution. Got me all confused now.
Ok, lastly. This Manix 2, upon examination before sharpening, had the factory edge and looked pretty even to me but I didn't straight up look for THAT specific detail but I'm sure I would have noticed if it was as off as mine is now. So my question is this. Why ? After the same amount of passes on each side of the blade is my bevel much wider ? I never count passes, I don't have a rule for passes, I work the blade until I'm happy with my bevel/edge/burr/scratch pattern and flip and the same on the other side.
Feel free to critique, criticize, tell me I'm an idiot, whatever. Just want to learn.
Side 1
Side 2
Side 1
Side 2
