Classic fixes include tightening the pivot, and firmly grasping both ends of the knife while closed and flexing the middle of the handle in the direction you want the tip to go. You can do this when the knife is open too, but I generally don't as I keep thinking I'll prolly cut myself. Generally speaking though this works better with benchmade linerlocks than axis knives, and I'm not sure but I'm willing to bet the griptillians don't flex nearly as readily as the G10 knives. Best bet is to play with the tightness of each handle screw, first make sure they're all roughly the same tightness then see if slightly tightening or loosening them will center the tip in the handle well. If all that fails then you either put up with it or send it back to the factory for servicing. I'd be willing to take apart their linerlocks to hand bend the liners, but the axis lock (710) that I took apart because I messed it up really bad was a real pain without the proper tools.
