- Apr 20, 2001
I just received this one a few days ago, Doug Ritter (Critter around here I think) and CRK&T teamed up with some other good folks to design a small survival tin/PSK knife.
You can read all the particulars here. Ritter MK5
It's a little cutter that's for sure, out of the box it's shaving sharp.
A few in hand shots. The lanyard cord really helps hang on to it, but they did a great job of curving the handle so that you can hold it and ridges on both sides keep it in place.
They recommend setting the lanyard knot, so that it's just past the edge of your hand, which works, but after playing around with it, I found another way that I like, set the knot a little further, so that you can slide your pinky inside the lanyard.
I used it to make an impromptu frog gig/spear and it worked just fine.
This is not a knife that I would want to be "lost in the wilds with only...", but it does work and could also be lashed to a limb as a spear head and lots of small chores around camp.
A good addition to a small PSK for sure, or piggybacked onto the sheath of a much bigger blade, and this one is a handy addition to a kit!
