- Aug 26, 2005
Well I only have about two inches to go on shaving my hawk handle . I just do a bit at a time cause it was perplexing me . I couldn,t get it to follow the taper of the eye for the last four inches . I finally figured out why . The taper is very uneven and even constricts somewhere inside the length of the taper . Its not a big difference just enough so that if it fits just right top and bottom the middle is too tight . I checked out the original handle and sure enough while the handle is nicely turned on a lathe it does not follow the contour of the head that closely . I tried ramming it on so as to see rub/friction scuffs I could shave down . The wood doesn,t pick up abrasions from the head . Now that I know what the problem is I will approximate the contour as best I can and accept its imperfections . I just wanted my first one to be as good as I can make it .
