Rock and Other Exotics as Handle Material
I thought I'd start this as a couple related threads have considered this. As art knives get more popular, more and more exotics are being considered for handle material. The old timers usually picked the best materials for long life. Stag is nearly bullet proof as is Rhino horn (compacted hair), and many woods, horn, bone, ivory have proven themselves. But as we get more exotic, we use materials that have flaws but are just danged beautiful. Mother of Pearl is a traditional choice but it breaks easily...doesn't stop its use...just too pretty. Stone has recently become more popular. Much of it is hard but brittle. Some is chalky soft.
There is stone and stone. One of the prettiest is jade-nephrite jade and jadeite jade. It is available in many colors and mixed colors, sometimes with crystals, gold, even gold platable magnetite mixed in. It is the best choice in stone as its crystal structure makes it nearly unbreakable. That is the curse of most stones. Many of them are harder than steel but they crack. Steel...even the hardest is less than a 7 in hardness. Most of the dirt around us is silicon which is a 7. Quartz and its varieties of agate and jasper and many other names is silica dioxide...hardness 7. It can be gorgeous...even appear to be wood (petrified or silified wood). But drop it and it can break. Of course, an art knife isn't meant to be thrown so if you wish to use petrified wood or dinosaur bone, go for it. I make pistol grips out of dinosaur bone (some are even identified). I use a backing material like G-10. I also drill the screw holes (diamond drills) a bit larger and then fill with epoxy then drill the regular sized hole through this. It all helps to preserve the dino bone (even after stabilizing). I have used this on the aforementioned stone, also jasper like bloodstone (which was actually petrified wood), ruby in zoisite, real malachite, Brazilian agate, corundum (non-gem sapphire or ruby if red), crysanthemum stone and more others than I can mention.
I had a genstone business for years, was a rockhound and stone cutter, took all the gemology courses, etc. If you have any questions, feel free to email me at peterb at coinet.com if you have a special project and we can likely figure out a way to accomplish it.
I really like your idea of using epoxy as a liner for holes, I never could come up with a really great solution for that problem. Thank you for the great tip!
I'm excited rock collecting season is starting here, collecting always gets me cutting a lot more stone. I'm on to a really nice rare Jasper, if I find the outcropping I might file a claim. I also bought an 18" Frantom saw and am picking it up this week! Now I can really start slabbing on the tons of rock I have.
How do you think stone compares to other exotic handle materials like mammoth tooth or ivory as far as durability goes?
Ivory has the best durability of those you mentioned. Mammouth tooth is likely rock although I have seen some like new. I taked to someone recently who deals in it. It needs to be stabilized then sliced, then stabilized again. But it is worth the cost. The stuff readily available from the North Sea is full of salt and cannot be stabilized. It is doomed to fall apart. Stick with Alaskan or Siberian. Most rock like jasper or quartz or agate is all the same, really. Hardness 7 but some is less likely to break than others. Petrified wood is a favorite of mine since it appears to be wood but with many neat colors. I have a fair amount of Arizona picture wood which has hot colors. It is hard to find without cracks, but I made a deal with a rock shop owner. I cut up her Arizona wood for free and bought the pieces that were large enough for my use. Worked out good for both of us.
Funny this should come up. I've been having thoughts of a project that uses some nicely patterned rock as a handle. The thought began when I plucked a nice specimen from the base of a waterfall here in WA. When wet the rock has two black-ish zones split by a white (likely quartz) band. When dry the black-ish zones turn medium gray. It fascinates me, and I think it would make an interesting handle... albeit heavy and coarse.
In the past I've collected many types of quartz that were beautiful to behold. I have long had a piece of bizmuth on my desk, and recently wondered if that could be used for anything. I stopped being a rock picker many years ago, but my eyes still wander when I'm in a scree field or a rocky shoreline.
- Greg
- Greg
It sounds like you could have anything but my first thought was quartzite. Post a photo or pm me one and I might be able to help if you want to id it. It is interesting how many rocks brighten up when wet. Watch how the rock dries too, after a lot of comparison it can tell you a lot, if a rock will polish, etc.
There is s very rare rock here called "Royalite" that is a quartz, purple flourite, and multi rock blend. It is bright purple when wet or polished but it just looks like a "rock" when dry. A lot of our local agate and petrified wood has a limey crust which disguises them. The main rock I collect, Rhodonite looks like big chunks of coal from the manganese oxide coating but when you slice it open the good stuff is hot pink!
It would be interesting to cut bismuth or use it in some way, I wonder if you could? I hope to make some bismuth crystals from bar one day in my kiln, I know a guy on another site who made a 4+ pound one!
A tile saw can cut stone into rough slabs and you can pick up a pretty good one from home depot to get you started for under $100.
Picked up some "rocks" cheap at the Monroe antique show today.
