Rockwell for cpm-m4
M.FREEZE
I am using .074" CPM-M4 stock and want to obtain the absolute best edge retention. I figure with .074" stock that the knife will be purely a cutting tool. How hard can I HT it to for best edge retention? Also, who do you guys recommend for HT?
I made a sheath for a friend's CPM-M4 knife and can say that he had put a very crisp, fine edge on it. I think it will do really well in a thin slicer. :thumbup:
I haven't worked with M4 yet, but Crucible recommends a range of 58-65Rc at specific hardening/tempering temperatures for optimized toughness and stress-relief. I think I would go right in the middle, at 62Rc. That's pretty hard, and CPM-M4 has healthy amounts of chrome, vanadium, tungsten and molybdenum that will form carbides and aid wear-resistance.
I highly recommend Peters' HT. Call them and ask for Brad Stallsmith, see what he thinks.
Peters is really good on complex stainless and high end tool steels. The only negative is that they are a professional HT company, and are not price geared to a small one at a time maker. They charge $25 for a single blade, but charge $100 for twenty blades. $25 is worth it for the job they do, however. They are fine with doing oit, and your blade will get the same attention as any big volume maker does. You can also send it over to another knifemaker who uses Peters, and have them toss it in the next batch they have going out to Peters. That way, it will cost $5-$10, plus a few bucks in shipping back and forth. It all depends on how much of a rush you are in.
CPM-M4 gets HARD. I would do a slicer at Rc 62-63. Just tell Peters that is the final target, and they will take care of the rest. I have done CPM-M4 large fillet blades at Rc64-65, and could not see any additional advantage. You will need a set of DMT plates to do the final edge, or you can use a grinder if you are set up for VS. I prefer stones/plates. Two 3X10" Duo-sharp plates and a holder are very affordable ( around $139), and will last forever if used correctly. That will go from X-coarse to fine.
I use Peters for M4. I think their "standard" HT for M4 yields about 62-63.
You don't need diamond for M4, you can also use Cubic Boron Nitride. :D
