Rockwell Hardness of Benchmade 950-1001 CPM-M4
Does anyone know the Rockwell Hardness of the Benchmade 950-1001 Rift with CPM-M4 steel?
Thanks!
Its not nearly hard enough. In fact, I've heard the HT is so poor, you should def sell me yours as soon as possible....
Ok that or I just missed out on that knife and I'm still butt-hurt over it lol. I have an Lum LFTi in same steel, was curious myself. Sending it to Tom Krein for a regrind here shortly, think may see Phil Wilson next for a re-HT as well. 58 is piss poor for M4.
Ryan, who did your HT?
My 950-1001 seems softer than my Spyderco Mule (tested at 62.5 RC) and my Spyferco Gayle Bradley in CPM M4 when I sharpen it and in edge retention. I am getting mine re heat treated song with my Bradley to 65 RC or so though anyway to see just how much performance you can get out of CPM M4, but I wil report the factory hardness after it's tested.
Mike
Mike
Phil Wilson did mine. I havn't had any chipping or any other trouble. 65 seems to be a good hardness for m4
Phil reported that at those hardnesses he is seeing wear resistance in the S110V/S125V category, If I recall that correctly. I don't want to put words in his mouth. That's pretty impressive stuff if so.
I haven't seen hardness numbers or tests but it should be stronger than any stainless steel that's run like that. It should be a pretty tough steel even at those RC's.
Sorry to bring this back from the dead, but would it be more worth while to send an LFTi back to Benchmade for Lifesharp and request a re-heat treating and sharpening or simply send it to someone else?
cotdt I tried to PM you but could not.
Benchmade definately will not heat treat your knife to a higher hardness. They will sharpen it for you though. If you want the hardness raised you will have to have a custom maker do the job. Check out the link above to get you started.
