Background:
Rockwell hardness testers work, briefly, by applying a known load to a small diamond tipped probe of known surface area. They make a small dimple in the test piece. Based on the depth of the dimple (really, the measured amount of deflection of the probe once load is applied), they can gauge the relative resistance to deformation of the underlying material...i.e. the "hardness" is related to how much it deforms or dimples during this test.
Ok ...
Talonite is very similar to Stellite.
Stellite was the original, but not made readily available in sizes and at prices for knife makers.
Both rely on a "tough" but relatively "soft", in knife terms, matrix made of Cobalt and Chromium. The matrix is a sort of tough carrier or support structure for hard carbides in this alloy matrix.
You'll see them referred to as CoCr alloys. This matrix is in the Rockwell 42-48 range on the "C" Rockwell scale, which by itself is well below the Rc range of 55-60+ needed for decent edge retention. The Rockwell testers will essentially give you the "hardness" reading on the underlying matrix of Talonite.
But that's not the whole story...
These CoCr alloys also contain enough carbon and enough other "carbide forming" elements such that very hard carbides exist in the alloy when produced. Here are the major carbide formers and their relative hardnesses per Crucible Services:
60-65 hardened steel
66-68 Rc for chromium carbides
72-77 Rc for molybdenum and tungsten carbides
82-84 Rc for vanadium carbides
With that background, here is a relative range of alloy composition for either Talonite or Stellite (my notes don't indicate which, but it could be Stellite 6K... Stellite 6K is the one usually used for knife blades, Stellite 6BH might get some use also):
Carbon: 0.9% - 2.0%
Chrome: 28% - 32%
Cobalt: 49.5% - 56%
Manganese: 2%
Nickel: 3%
Tungsten: 3.5% - 5.5%
Ok, see this link for further info on Talonite:
http://www.geocities.com/mdpoff/talonite.html
From that link, here is what MDP says is in Talonite:
Nickel 3% max
Silicon 2% max
Iron 3% max
Manganese 2% max
Chromium 28%-32%
Molybdenum 1.5% max
Tungsten 3.5%-5.5%
Carbon 0.9%-1.4%
Cobalt: the balance
Here is where some educated speculation on my part comes in: I think it is the Tungsten and Molybdenum carbides that gives the Talonite the heavy duty wear resistance, but Chrome Carbides very likely play into this very heavily as well. I'm making another educated guess that nickel and silicon may help with alloy toughness. (any metallurgists out there who know better, chime in!). A Rockwell hardness tester will in essence push these carbides to the side, or impact them into the CoCr matrix, and so their contribution to Talonite's abrasion resistance, or wear resistance (which translates to longevity of a slicing edge) will be unmeasured by this hardness test.
For sure, Talonite/Stellite will not corrode under any kind of reasonable thing you'd get your hands into. It takes strong acids or bases to really start to corrode this stuff. Arguably, Talonite would make the perfect salt-water knife, and salt water won't really touch it.
Drawbacks, only two or maybe three really:
1. cost... very pricey for raw stock so blade prices are high
2. The edge can roll sooner than other steels, but is easy to straighten up with a steel or on ceramic rods. It may loose it's "as sharpened" wicked-sharp quicker than other premium blade steels, but a very good underlying edge is retained so it will continue to slice and slice for long periods.
3. It won't take quite as wicked-sharp an edge as many other materials will, from simple carbon steels to 420V etc.
I have a couple of kitchen paring knives make of 6K. They are very thin, flexible, work great for paring. They hold a good edge, but it rolls easily if you cut into say a cutting board, but I'm tellin' ya', it only takes 2 to 4 very quick swipes on a steel to straighten the edge back up. Super easy to maintain.
I have no idea where a hardness level of 91 comes from. Can't even think of anything that is that hard, maybe some ceramics...but I'm not sure. I think diamond may be the Rc scale limit at 100, and none of the usual materials are at Rc 91. There may be some metal nitrides (Titanium carbonitride, or some other stuff... might try the Buck Knives page) that might go that hard.
Also try using the search engine on this forum for "Talonite" and "Stellite"...this ground has been covered, probably find a thread that is more detailed.
[This message has been edited by rdangerer (edited 05-27-2001).]
